Old 06-09-2007, 06:19 PM   #1 (permalink)
ajayritik's Avatar
Default Problem with DVD-RW
I'm having problem with DVD-RW Sony. I purchased two of them and both are not working properly. Can someone who uses DVD-RW give me suggestion/Advice on how to use these things? Do we need to take certain precautions so that they last for a longer time? Are there any other brands of DVD-RW available which are better than Sony? I purchased these for Rs 65 each. What is the difference between Quick Erase and Full Erase? Any specific software that we need to use to erase this DVD apart from the one that we get in Nero under tools.
ajayritik is offline
Old 07-09-2007, 12:47 AM   #2 (permalink)
slugger's Avatar
Default Re: Problem with DVD-RW
wat exactly is d problem u r facin
r u not able 2 write n e thin @ all?
RW disks r not very reliable and r prone to read-write failure after a few uses (@ aleast dat is wat happens to people around me who buy these thins)
u spent 130 bux on those 2 disx
4 dat much u cud have bot 11 DVD-R s and still have money left for a 300ml Fanta +1 chewin gum
well i dint really solve ur problem but i did give u a better option, dint i
slugger is offline
Old 07-09-2007, 10:47 AM   #3 (permalink)
ajayritik's Avatar
Thanks for the suggestion Slugger. The main reason why I purchased a DVD-RW is that when I burn some movies on DVD-R due to some errors I'm not able to burn movies properly and I end up losing lot of DVD-R's so I thought it would be better if I burn them first on a DVD-RW and later on DVD-R's but I guess that didnt work out as I had planned.
Old 07-09-2007, 10:56 AM   #4 (permalink)
Cool G5's Avatar
^What is the error?plz post it dude.
Lol.Good calculations.
Cool G5 is offline
Old 07-09-2007, 10:57 AM   #5 (permalink)
slugger's Avatar
if u cud tell us wat is d exact error message u r gettin then sum 1 will b able to help u out
preferably post a screenshot of d error message
in general it is advisable to burn the DVD-R @ a speed of 4x/8x
and use good qlty disks like Moser Baer or Sony for burnin
slugger is offline
Old 07-09-2007, 05:19 PM   #6 (permalink)
ax3
Cool as a CUCUMBAR ! ! !
ax3's Avatar
burn @ lesser speed ........
& use branded DVD`s ...........
... W H O T ...
ax3 is offline
Old 07-09-2007, 06:27 PM   #7 (permalink)
ajayritik's Avatar
When I burn movies on DVD-R it says burning operation failed. So I had to go for burning on DVD-RW. The problem is as follows:
After I erase the data from my DVD-RW I presume its blank infact that is the message it displays when I insert into the drive. however when I insert this blank DVD-RW into the drive during a Nero burn session when Nero asks to insert a blank disk that messag still is displayed on the screen telling insert a blank disc. I presume its not recognizing this DVD-RW. Normally during a Nero session of burning the moment you insert a DVD/CD it will start burning straightway or give a message telling the disk has insufficient space. But in my case it doesnt do either. It still shows the message Insert a blank DVD-R etc. So does that mean there is some issue with the media or the drive itself. I purchased the DVD Writer recently. Its liteon. Please help!
Old 07-09-2007, 06:34 PM   #8 (permalink)
Cool G5's Avatar
^nero doesn't start writing straightaway coz the CDRW u inserted isn't blank.use full erase option.Maybe this helps.
Cool G5 is offline
Old 07-09-2007, 06:35 PM   #9 (permalink)
try some other burning software or install older version of nero, most stable one is nero 6.6.0.14. nero v7 is buggy.
casual_gamer is offline
Old 10-09-2007, 12:10 PM   #10 (permalink)
ajayritik's Avatar
I have taken the DVD-RW to my friend's place and tried erasing and burning it on his computer. Guess what it was working alright! So is the problem with my Liteon DVD Writer. I dont know what to do! I purchased this DVD Writer recently not even a month back on friend's suggestion. Dont know what to do!
Old 20-09-2007, 07:23 PM   #11 (permalink)
ajayritik's Avatar
After updating with latest firmware for my Liteon DVD Writer I still face the same problem. My Writer doesnt recognize a DVD RW disc. When I tried to burn it in my friend's computer I'm able to burn it.
Old 22-09-2007, 05:00 AM   #12 (permalink)
Is actually a real word..
So what are they Sony drives or Liteon drives? I have a "liteon" (thats what it said on outside of box but is really a LG) I had problems until I downloaded latest firmware, and I have used my RW disk multiple times now, the disk are really scratched up but they still seem to have no problem writting and reading. So try a firmware update. if they truly are sony, throw them out the window... well personally I don't like sony... try firmware then get back to us here...
“They put me here because I’m from Canada and they think I’m slow, eh?..."
Liggy is offline
Old 23-09-2007, 01:19 AM   #13 (permalink)
ajayritik's Avatar
Yeah dude its a liteon DVD Writer with Sony DVD-RW. I have updated with latest firmware but the problem still persists. Unfortunately we dont have other brands of DVD-RW here in Hyderabad
Old 23-09-2007, 02:59 AM   #14 (permalink)
slugger's Avatar
y dont u take ur drive to ur friends place 2 c if it is actually d drive dat is givin u d problem or sum settin in ur OS
if it is not workin der also den u mite wan2 get it replaced (Liteon gives 1 yr warratny)
slugger is offline
Old 27-09-2007, 09:51 AM   #15 (permalink)
ajayritik's Avatar
I have tried burning the DVD's with other softwares like Image Burn and Infrarec but no success. I have a feeling it could have got to do with the DVD-Writer coz its not recognizing DVD-RW. My friend doesnt have SATA compatibility so maybe I have to look around for some other options.
Problem With Data Recovary Software Problem Stellar Phoenix njm Software Q&A 1 08-05-2007 12:31 PM
Problem Related To Dvd and Iso Buring , any genius here who can resolve this problem vijayendra QnA (read only) 2 14-01-2007 09:38 AM
Problem!Problem!Problem Help Me November Cd And December dvd Doesnt Work yyy??? sourav_digit QnA (read only) 3 27-12-2006 02:33 PM
Serius problem with my screen. Can u tell it s/w or hard ware problem . tusarks Hardware Q&A 7 12-06-2006 01:58 PM
fedora cd iso problem(installation from hard drive problem) harmax Open Source 3 01-07-2005 11:34 AM
