Hi guys....I want some help about my AMD X2 processor.since
2005 i had AMD Athlon processor 3200+ socket 754.Now i upgraded my Pc with AMD X2 4400+ (socket AM2) CPU and ASUS M2NPV-VM motherboard.I am satisfied with its outstanding performence.But i have little bit problem i.e when i want to navigate form folders to sub folders or viceversa.It takes more time than my former processor.After a month long hard work i came to a conclusion that in task manager processes have "CPU Affinity" there.As i have 2 core processor it showed me 2 cpu cores.And when i set the affinty of the "explorer" to only one core,whole problem was solved.Now i want to know is there any tweaking software or driver for optimizing the CPu afffiny for dual core.I upgarded drivers etc. but it didn't optimized the cores to their best performence..now i have to manually set the Affinity whenever i have to restart my PC.Is there any way. how can i solve this problem about CPU Affinity.one more thing is that went i set it to one core, all the applications will get executed on the same core thus increasing the load on only one core of processor..Is any body have any Solution to this problem please tell me...
