Old 11-03-2005, 01:35 AM   #1 (permalink)
Default *** Serious Drive Error ***
Hi Guys,
I tried to install win 98 onto my hard disk. But I cancelled the setup when it came to step asking me where to install the OS. Since then my C drive is not accesible.
When I connected it as a slave in another computer and checked its properties, the drive was labelled local disk and it was in RAW format. Both 'Used Space' and 'Free Space' read zero.
How can I retrieve my drive? It contains lot of vital data.
All help is appreciated.
vvk_2004 is offline
Old 11-03-2005, 02:31 AM   #2 (permalink)
I think You loose Your Administrator Rights,Just Check With Security Setting In Disk That U have Access Of Read,Write Etc Etc
If they are not then Click On security Make a Administrator right there!!
Hope It will Work
Reply Back!!
neerajvohra is offline
Old 11-03-2005, 03:37 AM   #3 (permalink)
Default Clarification ::
Hi neerajvohra,
Sorry, but I am not quite good with computers. Hence I was not able to understand what you want me to do.
To make things easier for you, I will tell you the drive labels.
Right now I have a working (bootable) Hard Disk which I use to look into my damaged Hard Disk.
Working HDD = MASTER Drive Label = C:
Damaged HDD = SLAVE Drive Label = Lshown as 'local disk')
If I connect my damaged HDD ALONE, it does not boot.
I hope I have stated the problem clearly. Now could you use the drive labels and tell me EXACTLY what I must do?
vvk_2004 is offline
Old 11-03-2005, 05:14 AM   #4 (permalink)
@vvk_2004,
looks like you have accidentally erased your harddrives partition info - or its corrupt. One way you can get back your files is using recovery software. Install it on your first hard drive (the one which is working) and search for lost files or folders. If you need such a software i can send it to you.
sailendra is offline
Old 11-03-2005, 08:06 AM   #5 (permalink)
Default Thanks
Hi Sailendra,
Thank you for the help. Along with the software please tell me what steps I must do to get my drive up and running using the software.
Thank you once again.
vvk_2004 is offline
Old 11-03-2005, 08:34 AM   #6 (permalink)
try running testdisk . its dos based and lets u show all the partitions that were there on ur pc . u can select which one is ur working one and then restore it through testdisk itself . It also helps u browse through lost partition so that u know if ur files are ok .
http://www.thinkdigit.com/forum/viewtopic.php?t=13783
If you make yourself more than just a man, if you devote yourself to an ideal... You become something else entirely
klinux is offline
Old 11-03-2005, 11:27 AM   #7 (permalink)
Default Re: Thanks
Originally Posted by vvk_2004
Hi Sailendra,
ok, i can send you the download link to the software. But you need to give me your email address.
Old 13-03-2005, 10:54 AM   #8 (permalink)
Default eMAIL ID
Hi Sailendra,
My mail is at:vvk_2004@rediffmail.com
Thank you.
vvk_2004 is offline
Old 14-03-2005, 09:05 AM   #9 (permalink)
ok, check your mail. I am getting a vacation auto respond mail.
