Old 10-03-2005, 08:10 PM   #1 (permalink)
mario_pant's Avatar
Default Where do i get the latest drivers!???
hey i have an abit motherboard which was in my compaq presario bought in 2002..... the details are attached PLEASE TELL ME WHERE TO GET THE LATEST DRIVERS??? and will the update do any effect??? and to tell u... i cudn't find my motherboard version in http://abit-usa.com/ download center..... i use a P4 1.6 Ghz.....
Motherboard
This module contains information about your motherboard.
Motherboard Information
Motherboard Model i845-W83627HF
Motherboard Vendor Abit
Motherboard Version BL30G v1.0
Motherboard Serial Number 6A69VA1B
Chipset Model Intel 845 (Brookdale) Chipset
BIOS Model Award Modular BIOS v6.00PG
BIOS Vendor Award Software Inc.
BIOS Id 11/28/2001-i845-W83627HF-6A69VA1BC-6J
BIOS Date 11/28/01
System Enclosure or Chassis
Chassis Type Desktop
Chassis Lock Present No
Boot-up State Unknown
Power Supply State Unknown
Thermal State Unknown
Security Status Unknown
Processor Info (from BIOS)
Socket Designation SLOT 1
Processor Type Central Processor
Processor Family Specific Pentium Version
Manufacturer Intel
Processor Version Intel Pentium(R) 4
Procesor ID 00000F12-3FEBFBFF
Supported Voltage(s) 1.6 Volts
Current Voltage 1.6 Volts
External Clock 100 MHz
Maximum Speed 4000 MHz
Current Speed 1600 MHz
Processor Status CPU Socket Populated, Status Enabled
Processor Upgrade ZIF Socket
L1 Cache Handle $09
L2 Cache Handle $0A
L3 Cache Handle N/A
Processor Family 80286 Family
Procesor ID 00002200-4FF6DC00
Supported Voltage(s) N/A
Current Voltage N/A
External Clock 20472 MHz
Maximum Speed 769 MHz
Current Speed Unknown
Processor Status CPU Socket Unpopulated, Status Unknown
L1 Cache Handle $00
L2 Cache Handle $00
L3 Cache Handle $00
__________________________________________________ _____________________________
Generated by FreshDiagnose (c) 2004, FreshDevices, Corp.
Thursday, Mar 10, 2005 08:00:13 pm
mario_pant is offline
Old 10-03-2005, 10:54 PM   #2 (permalink)
Go to the intel site and get an upate fr the chipset 845. This is wats important and needs updates.
I got the same problem initially then when came to know this.
Have a Nice Day :)
Mohammed Muchhala, © 2006, All Rights Reserved
http://www.muchhalasworld.com
babumuchhala is offline
Old 11-03-2005, 07:59 AM   #3 (permalink)
Laptoping
Sourabh's Avatar
get it here http://downloadfinder.intel.com/scri...nfinst_enu.exe
Sourabh is offline
