Old 03-09-2007, 03:21 PM   #1 (permalink)
Default Infection
Hi Friends
I think my computer is infected by virus, I am not able to view the hidden file, the folder option is not working. please help me
Sheik Rasheed K
Don't accept anything that costs joy.
Sheik Rasheed K is offline
Old 03-09-2007, 04:45 PM   #2 (permalink)
Ron
||uLtiMaTE WinNER||
Ron's Avatar
Default Re: Infection
I can't see Hidden files/folders in my computer. Even I enable the option "Show hidden files/folders" in "Tools -> Folder Options", its automtically disabled again.
Sol: Open regedit and goto:
HKEY_CURRENT_USER\Software\Microsoft\Windows\Curre ntVersion\Explorer\Advanced
In right-side pane, change value of "Hidden" to as following:
1 - To show hidden files
2 - To not show hidden files
If it doesnt work, then scan your computer with an anti-virus software.
Hey pls try to search the forum before........
||uLtiMaTE WinNER||
Ron is offline
Old 03-09-2007, 05:25 PM   #3 (permalink)
piyush gupta's Avatar
^^try this tip
if it doesn't work
goto hijact this and post your HIjack this log file here so that anyone of us can help u better
piyush gupta is offline
Old 03-09-2007, 05:41 PM   #4 (permalink)
slugger's Avatar
Originally Posted by Sheik Rasheed K
Hi Friends
looks like u have been hit by d Win32.Brontok.A@mm worm
if i'm not mistaken den u will b unable to open even d registry
Your options
1. Use d Brontok Removal Tool given in d link above
2. Run a virus scan using either Kaspersky or NOD32 (Recommended)
i recommend d latter bcos den u will b sure dat ur comp has been cleaned of all viruses
slugger is offline
Old 03-09-2007, 05:50 PM   #5 (permalink)
damn busy...
utsav's Avatar
at first i thought that the thread starter has got some infection
my pc is also not showing hidden files and folders when i scanned it using avast it found nothing.
what could b the problm
MSI GX660 with ATI 5870 :grin: ultimate gaming lappy :grin:
Dell Studio 15(1555)
1TB+1.5TB external|N86|ZTE Blade|5230|E63|EP-630|Soundmagic PL50|Sennheiser CXL 400|Meelec M11P+
www.techjunkiez.com
utsav is offline
Old 03-09-2007, 05:52 PM   #6 (permalink)
slugger's Avatar
click on d url i have given in my post above and download d removal tool
and follow d instructions given
slugger is offline
Old 03-09-2007, 06:22 PM   #7 (permalink)
Thanks all
Sheik Rasheed K
Old 04-09-2007, 02:57 PM   #8 (permalink)
may be brontork.q(qh name) virus.
abhijangda is offline
Old 04-09-2007, 03:30 PM   #9 (permalink)
dá ûnrêäl Kiñg
zyberboy's Avatar
These days avast is not good in catching virus...its missing many viruses...uninstall avast and download kaspersky 7 trial....sure tat u will find virus in ur compu.
My Stomach pains:D:D
http://tinyurl.com/32jj4m
zyberboy is offline
Old 04-09-2007, 07:46 PM   #10 (permalink)
saurabh.sauron's Avatar
use Spybot to remove the tool. It is just a worm.
saurabh.sauron is offline
Old 05-09-2007, 11:32 AM   #11 (permalink)
ajayritik's Avatar
Even I faced the same problem few times follow the instructions given by slugger it will work.
ajayritik is offline
Virus infection skghosh44 Software Q&A 5 28-08-2007 08:03 AM
virus infection:: ,.exe harmik Software Q&A 9 04-08-2007 02:53 PM
Trojan infection aneesh kalra Software Q&A 7 24-04-2007 09:32 PM
Trojano-g. Infection nooob QnA (read only) 3 14-12-2006 04:01 PM
spyware infection...please help ace1 Software Q&A 3 25-11-2005 07:24 PM
