Unban Praka123
Vista is my Secretary | Mac is my Girlfriend | Linux is my Wife
"Ek Se Mera Kya Hoga" :lol:
Be clear, do you know the name of the virus atleast? Its hard to identify viruses with the description you give, cause that's a common thing a virus would do, irritate.
i am using windows xp with sp2 in all my drives in my d,e drives 30 folders are there in every folder same name exe folder is there how can i remove that virus
it is not another folder it is creating inside d original folder
it is an *.exe file with d same name as d host folder (since d ext is hidden and icon same as dat of a folder, u will mistake it 4 a folder, DONT CLICK ON IT !!!!!)
same problem with my friends system...... he is not able to open any of his drive he just doing rite click and select open to open the drive........
i hope slugger solution will help him.... dude can u tell me what is AFAIK and KAv...... which u mentioned above.....
let me check and do reply........
my friend's machine is infected by........ vbs.asp
it create s the folder inside the folder with the same name
ex: if there is a folder named Qadir.... inside this folder it creates a folder with same name.......
can any one post the solution soon........?
plz guys.....
use qh to remove this virus it is a simple and not a dangerous virus. my friend slugger it is not neccesary that it is w32@Rontobork virus there are others also which do this.
