Old 10-03-2005, 06:24 PM   #1 (permalink)
Ignorance is BLISS !!
Default Connect 2 a friend's PC ?
Can any1 tell me the answer to the following question ?
I reside in WB, India ( , as if it makes things more precise )
my friend happens to reside in Allahabad !!!
We both happen to own a comp at home ( , thought u couldn't Guess)
But we are not a part of any network (I mean any other network except the Internet)
Still, we want to get access to each other's machine in a way that we can share files and any other stuff (I mean, everything !) only amongst ourselves !
He runs Win 98 SE and I run XP (with SP2).
How do I connect to his machine if I get to know his IP address ?
This is a short description of our sole try !
We went to a website that told us our current IP addresses !
We were chatting on Yahoo Messenger and hance told each other our respective IP addresses.
We pasted the IP address in the Internet Explorer (For those of you who do not know it ==> IE can act as the Windows Explorer of u view folders on UR machine)
BUT -----------------Nothing showed up !!!!!!!!!
Any1 ever tried it ?
Any suggestions ?
A complete ( & comprehensive ) guide is extremely welcome.
rajkumar_personal is offline
Old 10-03-2005, 06:52 PM   #2 (permalink)
We used to do this stuff using a software called pc anyware. But remember the throughput is limited by the lowest net connection that you have
**** happens
pradeep_chauhan is offline
Old 10-03-2005, 10:25 PM   #3 (permalink)
you can try VNC
i dont know the link roght now but google it up
valtea is offline
Old 11-03-2005, 12:01 AM   #4 (permalink)
Try radmin or author a program in vb to cater ur needs..Just a file manager will cater you needs ...
Correct me if iam wrong
h4xbox is offline
Old 11-03-2005, 12:24 AM   #5 (permalink)
Unless & untill there is a service residing there how do you expect to connect & make merry?
Dude even if you have the IP address,there should be some sort of service/s along with the respective port/s running for you to connect.For example a HTTP server,you can connect to www.thinkdigit.com just because there is a HTTP server running at port 80 by default or whatever the server has been configured to accept incoming connections.If there wasnt then you wouldnt be able to connect.On the same lines the remote desktop software normally consist of 2 parts,a client software & a server software.
Yes there are many ways to go about it.Either grab a third party remote control software like TightVNC,RealVNC or UltraVNC or use the remote desktop feature which is bundled with XP.Here is no bells no whistles tut which should get you alive & kicking with remote desktop ,but make sure it meets the requirements.
EDIT:Btw which operating systems are you trying to connect with?
www.Oobertech.net
digen is offline
Old 15-03-2005, 06:17 PM   #6 (permalink)
whoopy_whale's Avatar
Try Grouper
Grouper is a new Windows based application that allows users to share their personal media within private groups. Grouper uses P2P technology connecting you directly to your friends' hard drives where you can share large files in a safe, encrypted environment. Grouper is a simple install and requires no firewall reconfiguration.
whoopy_whale is offline
Old 15-03-2005, 09:27 PM   #7 (permalink)
Grouper is one hell of a software mate !
Thanks mate !
Nothing 2 serve my needs better !
Old 15-03-2005, 11:01 PM   #8 (permalink)
hack expert's Avatar
yup grouper just rocks
If electricty comes from electrons, does morality come from morons?
Flying is simple. You just throw yourself at the ground and miss
hack expert is offline
Old 16-03-2005, 07:33 PM   #9 (permalink)
It's cool,right?
I read about Grouper in PC Magazine
In just two days, tomorrow will be yesterday.
Old 17-03-2005, 04:45 PM   #10 (permalink)
veddotcom's Avatar
You Can Use The Software REMOTE PC CONTROL, Its so Simple to use
veddotcom is online now
Old 28-05-2005, 10:55 AM   #11 (permalink)
well can i connect my PC with my cousins who is having the same connection (sify broadband )
as we are having same network....
SO plz adwise
i think we can
abhinav is offline
Old 28-05-2005, 02:25 PM   #12 (permalink)
expertno.1's Avatar
now take the experts advice mr rajkumar
get ur friends phone no.
downlaod multicomm
www.softnews.ro/public/cat/4/5/4-5-9.shtml
i will allow u to do anything between the comps
plus the benefit is that the caler will be the bill payer
hope this solves
u can use hyper terminal also
abhinav
Warmed-Up Nerd
know ur cousins ip address
call him with the ip address
star talking!
u can use differnt software swhich allow u to connect two comps using ip address
thats all
expertno.1 is offline
