Strong Encryption - You can encrypt both standalone files and entire folders.
The high level of security is ensured by using the well-known unbeatable 128-bit key BlowFish algorithm.
What can you do with ABC CHAOS?
Easily encrypt files into your personal data archive. You can be confident that the data is safely secured.
The additional special protection completely excludes an opportunity of selection of the password to the encrypted information at use of the generator of the passwords and keys.
Chaos Mash is a free encryption utility for Windows that let’s you scramble any type of data. Encrypt any sort of file on your computer. If you need it to be confidential simply “mash” it. Chaos Mash will output any file of your choosing into encrypted data.
Chaos Mash does not require installation, simply copy it to the hard drive or USB device to run[/b]. Choose from 45 types of encryption methods. Use these methods with keys you create to keep your data safe.
