Old 10-03-2005, 04:40 PM   #1 (permalink)
Default virtual cd
Can any intelligent life form out there tell me how the hell can I create a virtual cd on my pc ????????????
Is ther any software for that
pleaze answer
divyaansha is offline
Old 10-03-2005, 04:51 PM   #2 (permalink)
kl_ravi's Avatar
Download Alcohol 120% from the below link.
http://trial.alcohol-soft.com/en/download_120.php
It is the best software to read even CD's with bad sectors and CD's protected with laser lock and securom technologies. ...
kl_ravi is offline
Old 10-03-2005, 04:51 PM   #3 (permalink)
simple u have nero u nero ? 6.x or any higher version ?
u have it on nero its a good one need other software !
Na na iam not going to give search on google !
vijaythefool is offline
Old 10-03-2005, 05:35 PM   #4 (permalink)
Another Brick in the Wall
drgrudge's Avatar
Mr. divyaansha, u r truly the greatest life forms and most brilliant as well..., dont order ppl here..
alcohol 120 is shareware...
Try virtual Cd
http://www.virtualcd-online.com/
I believe it's free as well...
drgrudge is offline
Old 10-03-2005, 06:25 PM   #5 (permalink)
yup virtual cd 6 ( dont remember the latest ver ) .
get it on digit feb cd .
n as drgrudge said , here u can only ask 4 help . nobody owez u nothing
the genius of the hole : no matter how hard u try 2 get 2 the top , 1 mistake n u start again
mamba is offline
Old 10-03-2005, 06:38 PM   #6 (permalink)
Ignorance is BLISS !!
U know something mate
There is a site called www.google.com
If you ever searched on it for "virtual CD" you will get the desired results
But hey !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
No hard feelings dude
You can get full versions at many places
If you r unable 2 find such a place, PM me and I will open the doors to the world where u will get many other things too !!!
rajkumar_personal is offline
Old 10-03-2005, 07:55 PM   #7 (permalink)
Y dunt try Fantom CD .. tht's also a gud one!
At times in ur life just to do things right U have to be steady & sacrifice sth which u want the most.....even ur dreamzz tooo....
yehmeriidhain is offline
Old 11-03-2005, 12:41 AM   #8 (permalink)
Nero works fine for creating ISO..
others are crap
h4xbox is offline
Old 11-03-2005, 02:48 AM   #9 (permalink)
parthbarot's Avatar
Alcohol 120% is best....for bas cds dvds also....CloneCD is also good....but dont use nero..its a big F**k
dont u no how to get rid of share/trial wares? hope evryone nos that...so u can do "THAT" think to make it "FULL"/"FOOL" & can use it forever...
or u can use freewares also...see my post of freewares here...http://www.thinkdigit.com/forum/viewtopic.php?t=16028
www.techlads.com
Paarth.
parthbarot is offline
Old 11-03-2005, 08:49 AM   #10 (permalink)
vysakh's Avatar
NERO is good only for burning into a CD. Alcohol is the best when it comes to creating images
Incompatible message format
vysakh is offline
Old 17-03-2005, 09:08 AM   #11 (permalink)
Default Thankx
THANX TO ALL OF YOU
I TESTED ALL THE SOFTWARES AND FOUND OUT THAT "VIRTUAL CD" IS THUS THE BEST ONE
THANX TO ALL
Old 17-03-2005, 09:58 AM   #12 (permalink)
Hey you can use the Drive Image tool that comes with nero or use Daemon Tools. Its small lite and is efficient
In the keyboard of life, always keep a
finger on the ESC key
shyam911 is offline
