Old 10-03-2005, 01:14 PM   #1 (permalink)
Default Notepad Error
Hi,
Notepad is my default application for opening .txt files.
But from last 2-3 days whenever i click on a txt file it gives an error.
Notepad has caused an error in executble notepad.exe
Application will now quit.
My notepad executable is perfectly ok and it works file when i open it using run command box or from start menu
Also when i open a file from nopetad,s File>>Open it works fine.
.I even replaced the notepad executable (c:\windows\notepad.ex) but the problem is not solved.It still gives error.
What could be wrong???
Lovedeep Wadhwa
cheetah is offline
Old 10-03-2005, 06:09 PM   #2 (permalink)
swatkat's Avatar
have u scanned ur PC for viruses?
using Search feature, find out if there r any other notepad.exe files in ur computer.
http://swatrant.blogspot.com/
swatkat is offline
Old 10-03-2005, 06:42 PM   #3 (permalink)
Ignorance is BLISS !!
VIRUS is the spoilsport for u mate !!!
Scan immediately !
rajkumar_personal is offline
Old 10-03-2005, 09:19 PM   #4 (permalink)
check ur file associations
Stay cool always!!!
cool_techie is offline
Old 10-03-2005, 09:27 PM   #5 (permalink)
Technoholik !!
Tech&ME's Avatar
Have u installed Microsoft Office alternative packages on your computer, like OpenOffice.org or any other FREE alternative. Most of this creates file association for themselves without warning u. So check that out. Check for file associations and remove the one u don't need or set windows default association for .txt files.
[Desktop]
[Laptop]
Tech&ME is offline
Old 10-03-2005, 11:41 PM   #6 (permalink)
Check for virus and also for file associations.. maybe adware/spyware/trojan too.. so scan thoroughly using avg..my worst nightmare
h4xbox is offline
Old 10-03-2005, 11:47 PM   #7 (permalink)
Check for virus and also for file associations.. maybe adware/spyware/trojan too.. so scan thoroughly using avg==>my worst nightmare
h4xbox is offline
