Old 10-03-2005, 11:28 AM   #1 (permalink)
Gaurav's Avatar
Default Help me Choose CD writer
Planning to purchase a new CD Writer. Please suggest some models, previously owned Samsung SW-224B (24X). I heard from some vendors that ASUS CD Writers are not good enough, "Bahut complaints aa rahi hain" all of them suggested LG,Samsung or Sony. What are your opinions in this. My machine's configration is as follows:
Pentium III 750 MHZ
Windows 98SE
Intel 810E chipset
256MB RAM
I need a writer which has great build quality and a much longer life. (don't need the fastest one). I hope you all understand what i am trying to say. Thankx
Gaurav is offline
Old 10-03-2005, 11:31 AM   #2 (permalink)
Laptoping
Sourabh's Avatar
get the ASUS one or liteon/sony
ASUS ki boohat probs aa rahi hain coz they have only samsung/lg stock moo profit in it
wod have to get ASUS from some other dealer not much profit
get it?
get the SONY/LITEON one else
it will cost u abt 1.3-1.4k
Sourabh is offline
Old 10-03-2005, 11:37 AM   #3 (permalink)
Gaurav's Avatar
You mean to say ASUS is a good performer as far as build quality and longer life is concerned. What do you say about Sony. Although vendor told me that if you want ASUS he can arrange it for me. what do you say. In which issue of digit CD writer test has been conducted. can you PM it to me right now. I'm online
Gaurav is offline
Old 10-03-2005, 11:40 AM   #4 (permalink)
Laptoping
Sourabh's Avatar
get the ASUS one
dun rely on DIGIT reviews
get it
if not SONY/LITEON
asus may be abt 150 rs highly priced
check the prices here if u r from southINDIA
http://business.vsnl.com/deltapage
Sourabh is offline
Old 10-03-2005, 12:29 PM   #5 (permalink)
Go for LG, SONY/LITEON or ASUS. I have been using LG CD Writer for the last two years i have never faced any problem till date (touch wood). But dont go for SAMSUNG at any cost.
Shwetanshu Srivastava
shwetanshu is offline
Old 11-03-2005, 12:54 AM   #6 (permalink)
My experience from installing dozens of CD-writers of various brands -
Liteon : performs well and none has broken down.
Sony : as above except that one died after about one year, but this could be a fluke or the owner did not take proper care of it.
Asus : good performance but 2 or 3 simply failed after a year or so.
LG : Have used only a few, so I can't really make a fair judgment, but I've seen some (not those I installed myself) that have trouble reading even lightly scratched CDs.
Samsung : they're the pits.
pimpom is offline
Old 11-03-2005, 01:12 AM   #7 (permalink)
busyanuj's Avatar
go for a Lite-On / Sony cdRewriter.
perform well. minimum disc rotation noise.
busyanuj is offline
Old 11-03-2005, 03:04 PM   #8 (permalink)
my choice will be ...
ASUS > Sony > Liteon > LG
nd samsung dont even come in the picture...
price is almost the same withing the range of 1100 to 1500 ...
grinning_devil is offline
Old 12-03-2005, 05:05 PM   #9 (permalink)
enoonmai's Avatar
Having suffered twice with Samsung drives, I would seriouslt advice you to stay away from them. I've been using a Sony DVD/CDRW combo and its got the best build quality I've seen in a long, long time. Stay away from Samsung!
Playing FEAR XP/LSW2
enoonmai is offline
Old 13-03-2005, 12:45 AM   #10 (permalink)
Go in 4 Lite-On blindly. No Samsung picks man. It sux!
Ish Karo... Ishq karna Tumhara Paidaishi Haq Hai........
Magar Kyon Na Is Bar Watan Ki Mitti Ko Mashuka bana le!!!
:) http://www.aseemn.org
Aseem Nasnodkar is offline
Old 16-03-2005, 02:41 PM   #11 (permalink)
godsownman's Avatar
Samsung is not the one we should choose.
They have many problems.
I personally had a problem with a samsung drive that was just about 23 hours OLD. Can you imagine.I switched to sony and now its working fine, touch wood.
Stay away from it Samsung
From the body of one guilty deed a thousand ghostly fears and haunting thoughts proceed !
Visit (http://www.meebo.com)
godsownman is offline
Old 16-03-2005, 03:13 PM   #12 (permalink)
Yoda's Avatar
I use samsung.
Till now no probs. for me.
Yoda is offline
Old 17-03-2005, 12:32 AM   #13 (permalink)
dOm1naTOr's Avatar
I think U should go for one from BENQ as they offer 2 year warranty on optical drives as opposed ti 1yr from other manufacturers.
I had just bought a new one just two days ago nd it also performs good.
U scould get a drive only from a local vendor(as optical drives are likely to fail anytime) who offer warranty so lasting wont be a problem.
I bought it for just 1300/-!!!!!!!!!!!!!!!!!!!!!!!
dOm1naTOr is offline
Old 17-03-2005, 10:51 PM   #14 (permalink)
My choice undoubtedly is Lite-On works gr8 though i have used LG and Samsung too but Lite-On scores over them. Go for Lite-On
Decius is offline
Old 18-03-2005, 01:28 AM   #15 (permalink)
man go for Liteon definetly because
most of the hardware engg use Liteon
Happy Computing :lol:
krishnathelord is offline
Old 19-03-2005, 03:18 AM   #16 (permalink)
sms_solver's Avatar
I think Liteon Black one is good. Only problem is that it makes a lot of noise
[ॐ एसएमएस॰सोल्भर ॐ]
sms_solver is offline
