Old 31-08-2007, 10:32 AM   #1 (permalink)
Exclamation how to scan my computer
hi friends plz guide me how can i scan my computer with an antivirus software what is the better way 1.safe mode ot normal mode
Ravi.Y
yrakesh78 is offline
Old 31-08-2007, 10:35 AM   #2 (permalink)
in search of myself
CadCrazy's Avatar
Default Re: how to scan my computer
No need to go to safe mode for scanning.Just open your antivirus window. Select scan , entire computer or individual drives.
BTW which antivirus you are using
Unban Praka123
Vista is my Secretary | Mac is my Girlfriend | Linux is my Wife
"Ek Se Mera Kya Hoga" :lol:
CadCrazy is offline
Old 31-08-2007, 10:54 AM   #3 (permalink)
sharma_atul85's Avatar
frst of all u need a gud antivirus n 2 update it...then there is an option of scanning ur entire drive or selected folders....
u may go for avast free edition n update it...then go for boot time scan....it pretty gud although not d best
sharma_atul85 is offline
Old 31-08-2007, 11:08 AM   #4 (permalink)
Smile Re: how to scan my computer
thanq friends
Ravi.Y
Old 31-08-2007, 11:34 PM   #5 (permalink)
Distinguished Member
anandk's Avatar
if ur av can schedule a boot-time scan (like, say, avast), its the best time.
else safe mode (dont think, say norton can scan in safe mode)
else then normal mode.
> www.TheWindowsClub.com <
= www.WinVistaClub.com =
Microsoft® MVP
anandk is offline
Old 31-08-2007, 11:37 PM   #6 (permalink)
Rebooting
Choto Cheeta's Avatar
More than Safe mode or notmal Boot... what Matters is under any condition, turn of the System Restore and run the scan from one Admin account which has access to portion of the HDDs !!!
rebooting
ChotoCheeta.com
Choto Cheeta is offline
Old 31-08-2007, 11:38 PM   #7 (permalink)
"The Gentleman"
vish786's Avatar
using avast 1 can do boot up scan(all local drives/selected folder) scan or normal scan after booting,
"The use of COBOL cripples the mind; its teaching should, therefore, be regarded as a criminal offense."
- Dijkstra
vish786 is offline
Old 03-09-2007, 12:49 PM   #8 (permalink)
ax3
Cool as a CUCUMBAR ! ! !
ax3's Avatar
just click the button "scan computer" ........ it will scan all ur partitions ......
... W H O T ...
ax3 is offline
Old 03-09-2007, 02:17 PM   #9 (permalink)
Nav11aug's Avatar
highly recommended :Update and perform Boot-time scan
http://www.last.fm/user/NOLFxceptMe/
http://naveendageek.blogspot.com
Back after a long time. And well, EndSems screwed up as usual :)
Nav11aug is offline
Old 03-09-2007, 03:05 PM   #10 (permalink)
can any one tell me what is this Boot time scan.......?
im using avast
qadirahmed is offline
Old 03-09-2007, 03:17 PM   #11 (permalink)
As said earlier you better you avast before that update the database
Sheik Rasheed K
Don't accept anything that costs joy.
Sheik Rasheed K is offline
Old 03-09-2007, 03:31 PM   #12 (permalink)
piyush gupta's Avatar
Boot time scan is bettr know as MBR scan.
IN Master Boot Record scan system scnas in first sector of HDD
before doing that it does POST(Power On Self Test).
piyush gupta is offline
Old 03-09-2007, 04:31 PM   #13 (permalink)
Nav11aug's Avatar
Start the antivirus(I mean the proper interface etc etc.) and then right click and u see a menu. Click "Schedule Boot Time Scan" .. reboot and relx
Nav11aug is offline
Old 04-09-2007, 03:01 PM   #14 (permalink)
surely safe mode as services not required for running windows didn't run.
abhijangda is offline
scan this CA50 QnA (read only) 14 22-07-2007 01:05 AM
Scan Disk stellar Software Q&A 4 11-07-2007 03:13 AM
scan disk purujitb Software Q&A 7 10-03-2007 05:36 PM
Port Scan ! ! ! ax3 QnA (read only) 5 21-08-2005 03:55 PM
