Originally Posted by Kerry
Well, the drive is accessible and also the newly installed program file opens normally while only the icon of the concerned drive is not there. Yes, there is one file in the drive 'Autorun setup information' where it is mentioned as [autorun]
icon=setup.exe,1
open=setup.exe
well it is bcos of that file
d
icon=setup.exe basically refers to using d same icon as is used by d file
setup.exe to represent d drive (e: in ur case)
so if u want den u can
simply delete dat file as infra_red_dude said (
afaik a simple delete will also work) and in ur next logon u will se ur e: drive respresented by its origianl icon (i doubt dat a simple refresh will work, 'cause dat icon is displayed is part of d OS shell)
and since u r getting dat strange icon it means dat d file
setup.exe is also not present in d desired location
so no point keepin d Autorun setup information file
serves no purpose
