Old 10-03-2005, 10:25 AM   #1 (permalink)
Gaurav's Avatar
Default how do i check
Hi all,
Please tell me that how do i check the USB ports on my computer are working or not without plugging a USB device as i am planning to purchase new USB printer. Thanks is advance.
Gaurav is offline
Old 10-03-2005, 10:35 AM   #2 (permalink)
Laptoping
Sourabh's Avatar
well i guess there is no way to check it without some device
generally theres nothing wrong
since u havent used it before chances are its working very well
if u r afraid that u buy a printer and it doesnt work, i wod suggest get hold of some cheap USB controllers like a gamepad,floppy drive, hdd, pen drive before buying a printer
i guess u can borrow that from somone near u and check it
Sourabh is offline
Old 10-03-2005, 11:15 AM   #3 (permalink)
Gaurav's Avatar
Few years ago my computer vendor checked the USB port by using a USB scroll mouse and it was not working. Scroll mouse (with ball) don't work on my machine (don't know why ). I think i will have to check the port with some other USB device. thanks for help.
Gaurav is offline
Old 10-03-2005, 11:20 AM   #4 (permalink)
Laptoping
Sourabh's Avatar
i hope u use windows XP sp2
coz win98 doesnt support many USB devices by default
make sure u have the right drivers too
btw which motherboard do u own ( just asking for knowing the no. of USB ports)
Sourabh is offline
Old 10-03-2005, 06:11 PM   #5 (permalink)
swatkat's Avatar
check that USB is enabled in BIOS...
http://swatrant.blogspot.com/
swatkat is offline
