Old 29-08-2007, 09:38 PM   #1 (permalink)
Wise Old Crow
blueshift's Avatar
Default External hard disk
Is anybody here using external harddisks?
I want to purchase the same upto Rs 2500 instead of 4GB pendrive.
I searched in eBay and found this 2.5 inch 30GB USB hdd but I dont know whether the brand is reliable or not.
Please suggest me any good external USB hdd upto 2500/-.
http://twitter.com/blueshift155
blueshift is offline
Old 29-08-2007, 09:41 PM   #2 (permalink)
hailgautam's Avatar
Default Re: External hard disk
you can have one assembled yourself. the casing will come for around 700 bucks + the cost of the hdd. i have a 3.5 inch hdd..
Change is Nature, the part that we can influence; and it starts when we decide.
Where you going?
With Luck forward.
hailgautam is offline
Old 29-08-2007, 09:42 PM   #3 (permalink)
Rebooting
Choto Cheeta's Avatar
There is a very good feature in the forum called Search !!!
http://www.thinkdigit.com/forum/show...60&postcount=7
rebooting
ChotoCheeta.com
Choto Cheeta is offline
Old 29-08-2007, 11:57 PM   #4 (permalink)
Wise Old Crow
blueshift's Avatar
Thank u both.
So now i need a laptop hdd and usb casing. Whats the price of 40gb laptop hdd? And are there any specific USB casing available or just anyone will do?
Yeah Search is a good option but it somewhat doesn't work in this forum. I tried searching in titles too.
Old 31-08-2007, 11:43 PM   #5 (permalink)
Wise Old Crow
blueshift's Avatar
I searched in google.
40gb laptop hdd Seagate @ Rs.2150
USB casing upto @ Rs.500
Old 31-08-2007, 11:56 PM   #6 (permalink)
"The Gentleman"
vish786's Avatar
put few more hunderds, u can get 80gb's if u wish too.
theirs no much price differe in 40 and 80.
"The use of COBOL cripples the mind; its teaching should, therefore, be regarded as a criminal offense."
- Dijkstra
vish786 is offline
Old 01-09-2007, 12:08 AM   #7 (permalink)
NP : Crysis
xbonez's Avatar
i recently bought one
80gb Western Digital laptop HDD + Zippy's 2.5" casing = rs. 2550
40gb ---------------------""----------------------- = rs. 2150
rates as per RR Systems, Nehru Place, New Delhi
The external hdd is amazing. its one of my best buys
xbonez is offline
Old 01-09-2007, 08:50 PM   #8 (permalink)
Wise Old Crow
blueshift's Avatar
Thanks xbonez for the prices. I hope there's not much difference here in Mumbai.
Old 01-09-2007, 10:21 PM   #9 (permalink)
NP : Crysis
xbonez's Avatar
shouldn't be too much of a diff. max +/- rs100. and remember to bargain. there's a lot of scope
xbonez is offline
Old 01-09-2007, 10:26 PM   #10 (permalink)
Google Bot
Pathik's Avatar
You ll get a 80gb seagate + casing(unbranded) at 2.4k..
Pathik is offline
Old 01-09-2007, 10:30 PM   #11 (permalink)
NP : Crysis
xbonez's Avatar
yeah. the prices i posted are about 3 months old. costs should hve dropped a bit now
xbonez is offline
Old 01-09-2007, 10:33 PM   #12 (permalink)
Rebooting
I found Opposite way in Kolkata, actually prices went up for the HDDs so last time had to fight to get a 80GB + Casing for Rs. 2500/- all incl
rebooting
ChotoCheeta.com
Old 01-09-2007, 10:52 PM   #13 (permalink)
NP : Crysis
xbonez's Avatar
thats strange. generally prices of comp related stuff drop...
xbonez is offline
Old 02-09-2007, 11:35 AM   #14 (permalink)
ax3
Cool as a CUCUMBAR ! ! !
ax3's Avatar
is better 2 have 1 ...... rather than burning DVD`s ..........
go 4 3.5 inch hdd + casing ........ cheap & more space 2 store .........
... W H O T ...
ax3 is offline
Old 02-09-2007, 01:39 PM   #15 (permalink)
NP : Crysis
xbonez's Avatar
if u're talking about 3.5" hdd casing that cases a normal desktop hdd, then yes it is definitely cheap. for the price of a 80gb laptop hdd, u'll get a 160gb desktop hdd. but it is large and also comes with a power adapter bec the power it requires can't be supplied via usb
so if u're just looking for a back up device go for the 3.5" one
if u're looking for portability, go for th 2.5" one - it gets its power thru the usb cable only
xbonez is offline
Old 05-09-2007, 03:40 AM   #16 (permalink)
i am getting 80 Gb seagate hard disk for 4000
and 160 Gb hard disk for 6000 .
Why there is huge difference in price, i asked dealer from ulhasnagar.
AMIT AGARWAL
AMITAGARWAL02 is offline
Old 05-09-2007, 09:12 AM   #17 (permalink)
NP : Crysis
xbonez's Avatar
whoa!! thats very expensive. You should get the 80gb hdd for max rs2800.
xbonez is offline
Old 06-09-2007, 07:07 PM   #18 (permalink)
Wise Old Crow
blueshift's Avatar
The only thing I didn't like is we have to carry a cable with ext hdd.
But still its a good option.
Need help on buying external hard disk rgajra Hardware Q&A 7 17-10-2008 09:17 PM
Which external USB Hard Disk to buy ? esumitkumar Peripherals 12 09-01-2007 06:09 PM
booting from external hard disk desijays Hardware Q&A 3 25-11-2006 08:58 AM
External Hard Disk varun_ag QnA (read only) 12 28-04-2005 10:56 PM
