Old 09-03-2005, 10:50 PM   #1 (permalink)
Default ip address
is there any way I can change my computer's ip address or it is fixed
iamtulipin is offline
Old 09-03-2005, 10:58 PM   #2 (permalink)
right click on ur lan card click on properties
double click on "tcp/ip"
thats where u can change ur ip address
BTW if ur trying to change the ip address of the card where ur ISP is connected then DONT u will not be able to connext to the net
if its ur internal lan ur connecting to then ok
if u wanna basically use another ip address for security purpose then u can use proxies from
http://www.tools.rosinstrument.com/proxy/
u can also use this
http://proxify.net/
better yet use a good firewall like zone alarm and ull be safe
No Mercy, No Limits.
theraven is offline
Old 09-03-2005, 11:01 PM   #3 (permalink)
why need title?
bharathbala2003's Avatar
depends on ya ISP.. if it supports Dynamic IP u can change.. else u cant
bharathbala2003 is offline
Old 09-03-2005, 11:30 PM   #4 (permalink)
hack expert's Avatar
yup if its dynamic u cannot do nothin
If electricty comes from electrons, does morality come from morons?
Flying is simple. You just throw yourself at the ground and miss
hack expert is offline
Old 09-03-2005, 11:41 PM   #5 (permalink)
lol buddy if the isp supports "dynamic ip addresses"
then the ISP will provide the ip address u cant change it
every isp has a pool of ip addresses it can assign
and thers no way for u to know which one would fall under its name
besides if its dynamic .. then u cannot reserve an ip address for urself
it just doesnt work that way
theraven is offline
Old 10-03-2005, 12:04 AM   #6 (permalink)
Why you wanna change ur ip?
If yours is a standalone comp without a network and a dial up connection
then the ip doesnt matter.
amitsaudy is offline
Old 10-03-2005, 01:20 AM   #7 (permalink)
Default Re: ip address
I think U wanna DO some Fun With Ip
Let me help you With that!!!
Edit by Deep : No one wants to learn ehtical hacking here sir I have editted the post, please make sure that you do not teach hacking lessons to anyone
Thats Some Rules Of "Ethical Hacking"
By Me!!!
Enjoy!!!!!!!!!!
neerajvohra is offline
Old 10-03-2005, 09:26 AM   #8 (permalink)
Ignorance is BLISS !!
MAC addresses can't be changed but you can screw ur IP address as many times as u want unless ur connected to the net via an ISP! But if u r a part of a LAN network, u can changethe IP address even if u r connected to the net !!!!
rajkumar_personal is offline
Old 10-03-2005, 09:34 AM   #9 (permalink)
Version 2.0
Deep's Avatar
rajkumar_personal, MAC address can easily be changed
Deep
- Deep Ganatra -
www.whoisdeep.com
www.twitter.com/DeepXP/
Deep is offline
Old 10-03-2005, 09:42 AM   #10 (permalink)
Deep
wow...i was under the impression that MAC address is a permanent one...
imprinted on NIC nd all...but after ur post, googled a bit nd found that it can be changed....!!
grinning_devil is offline
Old 10-03-2005, 10:30 PM   #11 (permalink)
Deep
Hey deep how can one go through this.
Sify has started id-ip mac binding. I got 40 kbps connection but my cousin got hrl pack with much higher speeds. Sunday was free so i used his ids on Sundays. But now its not possible.
Have a Nice Day :)
Mohammed Muchhala, © 2006, All Rights Reserved
http://www.muchhalasworld.com
babumuchhala is offline
Old 10-03-2005, 10:53 PM   #12 (permalink)
Version 2.0
Deep's Avatar
prop of lan connection - click on configure button - next to your lan card name..
there you will find option to change mac adddress
Deep
- Deep Ganatra -
www.whoisdeep.com
Deep is offline
Old 10-03-2005, 11:38 PM   #13 (permalink)
LOLZ !! so many replies when i thought i could pour off what i knew ... gr8 guys.. keeep it going
h4xbox is offline
