Old 29-08-2007, 06:42 PM   #1 (permalink)
User Name's Avatar
Default How to run the program at strart up
I hav deleted Entry of realtek soundcard. I want run this prog. again at start up.
how to do it?
User Name is offline
Old 29-08-2007, 06:55 PM   #2 (permalink)
Nav11aug's Avatar
Default Re: How to run the program at strart up
Start Registry Editor by typing regedit in Start>Run
Goto HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\Curr entVersion\Run .
Rightcilck in the right pane. Select New>String Value . Name this Alcmtr and enter Value Data as ALCMTR.EXE
Reboot.
http://www.last.fm/user/NOLFxceptMe/
http://naveendageek.blogspot.com
Back after a long time. And well, EndSems screwed up as usual :)
Nav11aug is offline
Old 29-08-2007, 07:06 PM   #3 (permalink)
M$™ Certified Spammer
entrana's Avatar
or u cud just copy the exe shortcut in the startup thingee in start-all programs and startup
p.s. there is a easy way for everything
Seagate 500gb 7200RPM l Corsair 2*1GB Ram 800mhz l XFX 8800 GTS 320MB Xtreme 650/ 1500/ 950 l Asus P5N-eSLI l Core 2 Duo e6750 l Coolermaster Extreme Power 600watts SMPS l Microtek 800VA Ups l
entrana is offline
Old 29-08-2007, 07:14 PM   #4 (permalink)
Nav11aug's Avatar
hey i have a doubt.. if everything cud be done this easy way , why do software designers hang in to registry entries and nonsense?
Nav11aug is offline
Old 29-08-2007, 08:51 PM   #5 (permalink)
slugger's Avatar
it can very well b done as entrana said
but 1 drawback of this method is dat it is very easy 2 delete d entry from d startup folder
once deleated d program will not run @ startup
sofware designers, esp, av dvp prefer doing it thru registry entries bocos if dey put d entry in d startup folder and sum1 deletes d entry den a program will not start- and u no wat will happen if ur nti-virus doesnot start
slugger is offline
Old 29-08-2007, 08:52 PM   #6 (permalink)
Nav11aug's Avatar
lol... yeah ... wudnt be here
Nav11aug is offline
Old 31-08-2007, 03:52 PM   #7 (permalink)
entrana's Avatar
but im sure the creator wants the easy way just to get the job done
and i suppose he wont delete it unless he needs to
entrana is offline
Old 01-09-2007, 05:06 PM   #8 (permalink)
Chetan1991's Avatar
If you know where the executable file is,then it is very easy.
You need a s/w like Tune Up utilities.Through it you can add as many programs to be run on startup as you like.
Pls rep me if it helps you.
Dell Inspiron 1564
i3 330M 2.13GHz
4GB DDR3 1066MHz
ATI M.R. HD 5450 1GB
298 GiB 7200rpm WD hdd
LG Optimus One P500
where-go-for-6-week-industrial-training?
Chetan1991 is offline
Old 01-09-2007, 05:21 PM   #9 (permalink)
Šupər♂ - 超人
koolbluez's Avatar
To add anything to startup.. just drop shortcut to StartUp button in Windows Start->All Programs... The StartUp button actually leads to a folder, the startup folder, where the shortcut'll b copied to... so next time... the application'll start auto...
koolbluez is offline
c++ program sai_cool Programming 18 19-08-2007 01:03 AM
c program saro_gn QnA (read only) 1 04-02-2006 03:21 PM
c program saro_gn QnA (read only) 4 14-12-2005 07:31 PM
a c program.. how to do it??? anubhav_har QnA (read only) 4 21-09-2005 11:54 AM
new program in 'close program menu' list and more....... vishakadatta QnA (read only) 2 12-04-2005 11:33 PM
