Old 29-08-2007, 03:47 PM   #1 (permalink)
Default low space in Drive C
Hello Everyone,
can any one help me to merge my primary [ c ] volume with any of my logical.. i tried acronis partition but i could not find the solution......
actually my drive c has 15gb which the all most full so im looking to merge it with other drive.. there is lots of free space....
i dont know the proper way how to do this.... this is the first time im trying to merge and to partition...... so i need ur help....
Plzzzzz guys help me in details.....
Thanks....
qadirahmed is offline
Old 29-08-2007, 03:56 PM   #2 (permalink)
slugger's Avatar
Default Re: low space in Drive C
u may try to use Norton's Partition Magic to do it
but backup critical data b4 atempting it
slugger is offline
Old 29-08-2007, 04:06 PM   #3 (permalink)
can it will work in demo version........?
Old 29-08-2007, 04:13 PM   #4 (permalink)
Google Bot
Pathik's Avatar
You ll have to keep atleast one primary partition...
Pathik is offline
Old 29-08-2007, 04:17 PM   #5 (permalink)
sorry dude i didnt get u......... can u explain me in details......? plzzzz
using acronis partition am able to merge disc F and G but not the c and G....
what may be the reason.......?
Old 29-08-2007, 09:57 PM   #6 (permalink)
slugger's Avatar
AFAIKNorton's Partition Magic shud b able 2 merge active partitions
if is not able 2 do it den u can use Gnome Partition Editor to merge c: drive dat is ur active partition with any logical drive in ur extended partition d: e: f:......
u will probably have to use d live CD or d liveUSB 4 dis
HOW TO RESIZE PARTITION
slugger is offline
Old 29-08-2007, 10:15 PM   #7 (permalink)
Cool and Calm
abhi_10_20's Avatar
or...1st try emptying c drive as much as possible, defragment it and then use any of the above mentioned s/w's..this cud work...
When Roger's at play, opponents pray..!!!!! :twisted:
abhi_10_20 is offline
Old 29-08-2007, 11:32 PM   #8 (permalink)
Im so sorry dude as a newbie....... i dont know what is live CD or live USB can you tell me what is this.........? plz dude plz dont mind..... im really feeeling very guilty.... to say this....
Old 29-08-2007, 11:42 PM   #9 (permalink)
slugger's Avatar
arre!!! no need to feel guilty yaar
every body is a n00b, even after havin 4000+ posts
liveCD is a bootable CD like d ones provided by DIGIT for their linux distro ....just pop in d CD and Linux starts running. that is Live CD
LiveUSB is is d same just that instead of CD u are using Flash drive (pen drive)
just go thru d instuctions carefully read it more than once if needed and den if u have ne queries post it here
but remember BACKUP UR DATA B4 U START RESIZING.....VERY....VERY IMP
slugger is offline
primary partition..... yoursnayak Software Q&A 4 03-07-2007 11:44 PM
primary partitions yoursnayak Hardware Q&A 1 03-07-2007 09:08 PM
which ide cable pin is primary? sknowonweb Hardware Q&A 2 31-12-2005 02:12 AM
Help me to change my primary prtition.. digant_goyal QnA (read only) 1 11-04-2005 12:43 PM
primary partitions.... ZiOn QnA (read only) 4 04-11-2004 02:03 PM
