Old 28-08-2007, 09:23 PM   #1 (permalink)
damn busy...
utsav's Avatar
Exclamation can i use two different latency DDR RAM modules together
can i use two different latency DDR RAM modules together.
help me plz
MSI GX660 with ATI 5870 :grin: ultimate gaming lappy :grin:
Dell Studio 15(1555)
1TB+1.5TB external|N86|ZTE Blade|5230|E63|EP-630|Soundmagic PL50|Sennheiser CXL 400|Meelec M11P+
www.techjunkiez.com
utsav is offline
Old 28-08-2007, 09:44 PM   #2 (permalink)
slugger's Avatar
Default Re: can i use two different latency DDR RAM modules together
AFAIK u can
just ensure dat in d BIOS ur RAM latency is set according to d higher latency RAM else it will not b detected
i can say dat with a certain amunt of confidence 'cause i got 2 with 2 diff latencies
wen i reduce d latency to 1.5 only 1 RAM is shown, whhereas wen i increase it to 2 both shown
slugger is offline
Old 28-08-2007, 09:59 PM   #3 (permalink)
damn busy...
utsav's Avatar
i hav award bios in my biostar (via chipset mobo)
where can i find its settings
i only find this relevant in the bios
sdram cas latency
it is currently set as 2.5
should i change this
www.techjunkiez.com
utsav is offline
Old 28-08-2007, 10:06 PM   #4 (permalink)
slugger's Avatar
dun remember d exact location right now
just check out sum section called RAM latency it shud have valu like 2-2.5 or sumthin similar
i can tell u d exact location only after i shut it down and restart it
will shut it only tommorow morning
accha!! u found it
ya dats wat i was talikn abt
just reduce it by 0.5 nd c upto which point both RAM detected
d lowest point up2 which dey both r dtected shud b ur RAM latency
slugger is offline
Old 30-08-2007, 12:07 PM   #5 (permalink)
damn busy...
utsav's Avatar
my friend has a intel 845GVSR mobo and he bought a 256 MB DDR 400 RAM frm me .he had a 128MB 333Mhz ram in his system but he is now unable to use both ram sticks together.only the 400MHz ram is detected even when both d ram sticks r inserted in d slots
www.techjunkiez.com
utsav is offline
Old 30-08-2007, 01:43 PM   #6 (permalink)
slugger's Avatar
change BIOs settings to fail-safe defaults and c if dey r detected or not
slugger is offline
RAM Different Modules stellar Software Q&A 8 22-07-2007 10:24 PM
Queries regarding Latency of RAM sainit Hardware Q&A 7 28-05-2007 11:00 PM
CAS latency of the ram which one should I buy? ranjan2001 Hardware Q&A 19 19-01-2007 11:10 PM
What is CAS Latency in RAM hotdogXP Hardware Q&A 1 28-01-2006 03:08 PM
Changing the CAS latency of RAM???? yesh_1683 QnA (read only) 2 17-03-2005 06:58 PM
