Old 28-08-2007, 08:28 PM   #1 (permalink)
Default problem in "view" of "folder options"
heloo frnds..
recently i had formatted my C:\
after dat because of viruses "microsoftpowerpoint.exe" n "autorun.inf" i kept my hidden folders showing(unhidden)...
but after i click "ok" ..d hidded folders do not show up..
n also d option in "view" remains "do not show hidden folders n files"
all my tries 2 change it 2 "show hiddedn files n folders" were in vain..
n i m still unable 2 c my hidden files n folders..
i need 2 show my hidden files n folders..plz tell me a method
mind021 is offline
Old 28-08-2007, 09:44 PM   #2 (permalink)
in search of myself
CadCrazy's Avatar
Default Re: problem in "view" of "folder options"
Your pc is still infected . Try it scanning with some good antivirus Kaspersky or NOD 32. Or try online scan from Kaspersky or Bitdefender
http://www.kaspersky.com/scanforvirus
http://www.bitdefender.com/scan8/ie.html
Remember the damn bitdefender online scan reuire Internet Explorer. Du no work on Firefox
Unban Praka123
Vista is my Secretary | Mac is my Girlfriend | Linux is my Wife
"Ek Se Mera Kya Hoga" :lol:
CadCrazy is offline
Old 28-08-2007, 09:47 PM   #3 (permalink)
slugger's Avatar
d00d search d forum b4 postin
dis topic has been discussed zillions of times on dis forum
REPORTIN
slugger is offline
Old 30-08-2007, 01:05 AM   #4 (permalink)
thnx...
but i hv heard d updates of nod32 n kasperasky r not easily available..
c i dont hv net on my system...instead i use it in comp lab of schul..
mind021 is offline
Old 13-10-2007, 07:28 AM   #5 (permalink)
Lightbulb Re: problem in "view" of "folder options"
hi this is a simple problem !! my solution is not a permanent but it will show the hidden files and also hide them . . . your pc is still affected by malware. . . go to run box and type regedit . . registry opens and then go to current user -->software-->microsoft-->windows-->current version-->expolrer-->advanced. . . u will see a hidden named dword key in the right pane . .double click it and edit the value as 1 or 2. .
type 1 for show hidden files and export this key to any drive .
type 2 for do not show hidden files and export it.
so whenever u want to see hidden files just merge that registry key where u have saved . it will definitely solve ur problem.
kavran_b4u is offline
Old 23-01-2008, 01:43 PM   #6 (permalink)
hey thanks buddy.
and also we can put any other num istead of 2 for hiding the things....but for showing surely we have to make it 1
it surely wroks....thanks a lot
http://thenamemanish.blogspot.com/
mind021 is offline
VISTA TUTORIAL: Add "Hide File Names" Option in "View" Menu of Folders Vishal Gupta Tutorials 7 27-06-2007 10:46 PM
"INF Error", VGA Driver "Missing" Installing ATI Catalyst Drivers CannedLizard Hardware Q&A 4 29-07-2006 12:47 AM
"Folder Options" unavailable...help!!! linardni QnA (read only) 2 11-06-2006 07:51 PM
can't name a folder "con" or "lpt1" club_pranay Software Q&A 1 23-11-2005 03:14 PM
