Old 28-08-2007, 03:57 PM   #1 (permalink)
die blizzard die! D3?
The_Devil_Himself's Avatar
Default RIAD help
I am planning to purchase a new hard disk and I was thinking of putting it in raid configuration with my existing hd.But I don't know much about RAID.My existing hd is WD 80gb sata 7200rpm.Do i need to buy hd with same capacity or company to enable raid?I was planning to buy a seagate 250gtb sata2.
And how do I confirm if my motherboard support RAID or not?
Stealing your women and horses since 1843.
The_Devil_Himself is offline
Old 28-08-2007, 05:17 PM   #2 (permalink)
in search of myself
CadCrazy's Avatar
Default Re: RIAD help
Duno much abt RAID but as far as i know both the HDD should be of same size and your old hdd may be SATA 1 .Now a days SATA 2 are easily available . So your old HDD will be bottleneck.
Unban Praka123
Vista is my Secretary | Mac is my Girlfriend | Linux is my Wife
"Ek Se Mera Kya Hoga" :lol:
CadCrazy is offline
Old 28-08-2007, 05:24 PM   #3 (permalink)
String Phreak
mediator's Avatar
Hdd Casing => Another option!
mediator is offline
Old 28-08-2007, 05:27 PM   #4 (permalink)
in search of myself
CadCrazy's Avatar
Unban Praka123
CadCrazy is offline
Old 28-08-2007, 06:13 PM   #5 (permalink)
slugger's Avatar
u can config ur HDDs in Raid only if their capacities match
so if u wan 2 setup a RAID config 4 ur HDDs u will have 2 buy another 80GB Hd if u insist on usin d older 1
and sinc u wan 2 use 2 HDDs u can arrabnge dem in
RAID 0 (speed)
or
RAID 1 (fault tolerence)
d bes way 2 check if ur mobo supports RAID config is 2 check out ur manual
slugger is offline
