09-03-2005, 06:08 PM
Help!!!!!!!!!
I have win xp and win98se.win xp without any service pack,when run runs for 30 minutes bfor restarting itself.next time,it restarts after 15 mins and next time after 5.next time it restarts barely when it has started.help me.i have no probs with win 98se.i have p3 933mhz,192mb ram.
RJ THE GREAT
09-03-2005, 08:20 PM
Might be the processor is gettin heated up.. or ur smps is gone kaput..
..::The Slam Team::..
09-03-2005, 09:26 PM
@slamteam, read his post, he said Win98 is working alright...
@ranjodh, which AntiVirus do u use?
yea, get the Mcafee Stinger and run it once...
update ur AV and scan ur system with it....
if u dont have any AV at all, then get nod32 and scan ur PC.....
http://www.nod32.com/download/trial.htm
before using HijackThis, learn how to use it here....
http://www.thinkdigit.com/forum/viewtopic.php?t=15729
http://swatrant.blogspot.com/
10-03-2005, 12:07 AM
u didnt mentioned the problem correctly. when the computer restarts?? when u 're connected to net or to a LAN etc??
as most of them mentioned try those removal tools
10-03-2005, 01:22 AM
Re: Help!!!!!!!!!
Just Explain it Much,MAy be some spammers or trojans Has Started Your Shutdown To a Fix Time,Check For Viruses trojans and spammers!!
Then Reply
10-03-2005, 09:22 AM
Ignorance is BLISS !!
ONE GOOD SOLUTION !!!!!!!!!!!!
Format ur machine and reinstall everything (backup ur data beforehand, though)
If the prob persists, that depicts that u got ur hardware screwed !!!
10-03-2005, 09:45 AM
dats not a good solution...if u consider killing a fly with a cannon then it can be considerd a gud solution...moreover i'll be formatting my PC 6/7 times per month in this way....
11-03-2005, 05:24 PM
i have ad-aware se and avast! antivirus installed .i checked for viruses,spyware etc but found none of them.
the problem occus eveyime no matter what i am doing
no msgs b4 restarting.none at all.it just restarts and then it says improper shutdown.
yeah,win 98se is working perfectly.
any suggestions?
PLease HELPPPPPPPPPP me..
and i am not going to format my system.i've had enough of it.
RJ THE GREAT
11-03-2005, 05:57 PM
re
hi,
if you didn't find any virus, try reinstalling winxp. or ifit was working fine before then try system restore.
26-03-2005, 07:18 PM
see,that prob is gone somehow.thanx for ur support.now,i'll b glad if u could help me with these two issues:-
1)i want a free partition manager which can easily split and most importantly,merge fat32 partitions without losing data.i tried partition magic etc but those are demos ,they don't apply changes.Plz help me.
2)i have a nokia 7610 and i want to transfer data to it with my friend's win 98se sytem.nokia pc suite doesn't install on it.so is there any other way.what to do????
PLZ HELP ME.
RJ THE GREAT
29-03-2005, 10:58 AM
ClubHost.in
Re: Help!!!!!!!!!
Seems u got the Blaster worm.
Download the Hotfixes from the microsoft site and it will solve the problem.
29-03-2005, 06:38 PM
see,i have checked 4 viruses.there's no virus.plz try and solve my current probs.for details look at my last post. I'll b highly thankful to youi all.
RJ THE GREAT
Search this Thread |
