Old 27-08-2007, 03:28 PM   #1 (permalink)
-----ATi-----
nvidia's Avatar
Post **Frames Per Second**
HI,
Can anybody suggest me a freeware that helps me to see how many FPS i get in a game?? And tell me any freeware that helps me to record the game happenings...
nvidia is offline
Old 27-08-2007, 03:33 PM   #2 (permalink)
a_g = JPKN
s18000rpm's Avatar
Default Re: **Frames Per Second**
FRAPS
www.fraps.com
ASUS K53SV SX520D + BF3
s18000rpm is online now
Old 27-08-2007, 03:42 PM   #3 (permalink)
-----ATi-----
nvidia's Avatar
i tried that but its not a freeware
nvidia is offline
Old 27-08-2007, 04:06 PM   #4 (permalink)
FRAPS has a freeware "lite" version...
Arun
sakumar79 is offline
Old 27-08-2007, 05:43 PM   #5 (permalink)
a_g = JPKN
s18000rpm's Avatar
Download - http://www.fraps.com/download.php
with the free version you can only record for 30seconds (per video) & get free watermark (frap.com) on the video.
Old 31-08-2007, 09:22 PM   #6 (permalink)
TopTrix
pravinbv's Avatar
SUPER
u can use this to covert all audio and video files from any format to any.
i also show all detaild analysis of any files including frames per seconds, bitrate, codec and all those things u want. just drag and drop a file in software and double click on the file entry.
pravinbv is offline
Old 01-09-2007, 04:47 PM   #7 (permalink)
Chetan1991's Avatar
Isn't there a better freeware s/w with more time limit??
Dell Inspiron 1564
i3 330M 2.13GHz
4GB DDR3 1066MHz
ATI M.R. HD 5450 1GB
298 GiB 7200rpm WD hdd
LG Optimus One P500
where-go-for-6-week-industrial-training?
Chetan1991 is offline
Old 01-09-2007, 05:33 PM   #8 (permalink)
I am Optimus Prime
navjotjsingh's Avatar
Download GameCam - http://www.planetgamecam.com/?locid=download
Its Freeware with no time limit. But you can't record Audio with unregistered free versions.
There are 2 versions
GameCam
GameCam Lite
Both versions are available for free(unregistered) or paid(registered).
So that makes 4 versions of which 2 are freeware.
Compare Free and paid versions: http://www.planetgamecam.com/?locid=compare
Hope this helps you.
One more thing..If anybody wants to buy, GameCam is much cheaper than Fraps.
Fraps Price: 37$
GameCam Price: 24.95$
GameCam lite price: 9.95$
navjotjsingh is offline
Video frames printed onto transparency film koolbluez Tutorials 1 04-05-2007 07:08 PM
Should frames be used in HTML designing? tuxfan QnA (read only) 17 03-10-2005 11:43 AM
