ok pritish.did u have install windows or linux.i will assume that you install windows(whatever it is).then put the windows os cd and run it.it will check all the drivers and ask thet you have accept the microsoft windows agreement or not?then it will go to the partition screen.in this you have create or delete the partition and format.(anything you will do).
