Old 26-08-2007, 06:38 PM   #1 (permalink)
clmlbx's Avatar
Smile problem while changing the path of my music
I guess it is done like this:-
1. regedit
2. Navigate to HKEY_CURRENT_USER \ Software \ Microsoft \ Windows \
CurrentVersion \ Explorer \ Shell Folders.
3. Right click on the folders you want to change and select Modify or double
click it.
4. change the path ( In my case d:\others\music) and then reboot
now problem is after reboot nothing happens . I checked regedit and and I got to know that path has been changed to dafault agian .
I tried it 4 -5 times and the same result ( path changed to default ).
what is the problem and what is it solution ?
clmlbx is online now
Old 26-08-2007, 08:54 PM   #2 (permalink)
swatkat's Avatar
Default Re: change path of my music
Hi,
Try using Tweak UI. Get it here:
http://www.microsoft.com/windowsxp/d...powertoys.mspx
http://swatrant.blogspot.com/
swatkat is offline
Old 26-08-2007, 11:23 PM   #3 (permalink)
clmlbx's Avatar
Ya, It Can Also Be Done By Using Tuneup Utilities
But I Want To Do It Manually
So Any Solution
Old 27-08-2007, 12:17 AM   #4 (permalink)
swatkat's Avatar
Did you try this:
http://www.infopackets.com/channels/...tures_path.htm
See the "Side Note" present in that link.
Also, check out this page:
http://www.kellys-korner-xp.com/xp_shell_folders.htm
swatkat is offline
Want help with Path of Neo debsuvra Gamerz 2 31-05-2007 10:36 AM
how to change the starting XP music? rup Software Q&A 3 01-04-2007 11:19 PM
How to change the path in "general" tab in services? Dongay Rajasekhar Panda QnA (read only) 2 13-09-2006 08:54 PM
change windows xp startup music? abhineet Software Q&A 3 13-05-2006 08:20 PM
The Matrix: Path of Neo anilthomas26 Gamerz 8 03-10-2005 01:54 AM
