Old 26-08-2007, 05:44 PM   #1 (permalink)
a_k_s_h_a_y's Avatar
Red face creating our own text editor..some help plzzz
guys am creating a text editor !! and now first thing that i am trying to do is write characters into the video buffer which starts at 0XB000000L (obvioulsy colour monitor) !!
first thing i will implement is type and save feature only that too with fixed name....u see am a C newb..
i try to write into video buffer but nothing is displayed the cursor is properly moved coz the second part of the prog works !!
can u tell me where the error ??
here is the code
#include <stdio.h>
#include <dos.h>
main(void)
    char *vram_start=(char)0xb8000000l;
    char *v;
    char a[100],scan,ascii;
    int i,j,x=0,y=0;
    union REGS ii,oo;
    v=vram_start+x*160+y*2;
    while(1)
        while(!kbhit());
        ii.h.ah=0;
        int86(22,&ii,&oo);
        scan=oo.h.ah;
        *v=scan;
        v++;
        ascii=oo.h.al;
        *v=150;
        *v=ascii;
        v++;
        *v=152;
        x++;
        ii.h.ah=2;
        ii.h.dh=y;
        ii.h.dl=x;
        ii.h.bh=0;
        int86(0x10,&ii,&oo);
the cursor properly moves the next position on screen but no char printed which i hit on keyboard !!
plzz help..thank u !
also plzz explain the concept of video buffer and the scan code of keys and ascii code of keys in detail also what is scan code of various keys..and wht about ascii code of F1 ?? ( i did write a prog to print ascii codes...but there obs u cant know which is the one for F1.. )
Sony Ericsson Flashing, Modding, Patching, Hacking And More !
http://www.akshayy.com/sonyericsson/
a_k_s_h_a_y is offline
Old 26-08-2007, 05:56 PM   #2 (permalink)
Google Bot
Pathik's Avatar
Default Re: creating our own text editor..some help plzzz
^^ dunno much about C but if u want to make GUi apps then better use java or visual c# .net
Pathik is offline
Old 26-08-2007, 05:59 PM   #3 (permalink)
no no its dos text editor ! later make it windows text editor !
i heard that all system software better written in C....is this true ??
i even read that OS is written in C so this text editor also better in C na !
Old 26-08-2007, 06:05 PM   #4 (permalink)
Google Bot
Pathik's Avatar
I dont think that a text editor ll ever interact much with the system..
Pathik is offline
Old 26-08-2007, 09:22 PM   #5 (permalink)
swatkat's Avatar
Hi,
If you are using NT based OS (NT,2000,XP and above), it's not possible to directly access hardware buffers from User Mode. Moreover, NT based systems don't even have "real" DOS. Accessing hardware is done through drivers in these OSes.
So, to display characters or doing other stuff in Command Line, you need to use console APIs, or standard CRT functions. More info about console APIs:
http://msdn2.microsoft.com/en-us/library/ms682010.aspx
http://msdn2.microsoft.com/en-us/library/ms686971.aspx
http://msdn2.microsoft.com/en-us/library/ms682073.aspx
http://swatrant.blogspot.com/
swatkat is offline
Old 26-08-2007, 10:52 PM   #6 (permalink)
^^^ hey thanks a lot yaar...there is lot to read in that website
our HOD told we hv to sue ISR no 22 and get the job done.....i just wanted some one tell error in my prog.....coz my friend wrote almost something same and it worked for him....got to ask him for wht's the correct way !!
text editor?? NagpurDaMunda QnA (read only) 8 19-03-2007 07:06 PM
New Text/Code editor koolbluez Technology News 15 08-02-2007 07:33 PM
HELP-problem in nokia text message editor cerebral_stroke Buying Advice 3 19-01-2007 07:18 AM
Can't open ANY text editor! Simple_Graduate Software Q&A 3 21-10-2006 11:35 AM
Opensource / Freeware text editor prajal Open Source 6 04-10-2006 09:09 PM
