Old 26-08-2007, 10:27 AM   #1 (permalink)
TopTrix
pravinbv's Avatar
Smile many questions. plz answer.
Dear friends
I have SE W700i mobile but here are some queries about it.
2. I think it should play .aac files but my phone is not playing it.why?
3. why ringtone is not ringing in headphone.
4. is there any free(not trial and no registration require) english-english
dictionary for java phone.
5. what is the use of my friends option in messages.
some qustions about my pc.
1. Do my motherboard support for DDR2 ram its asus "p5rd1vm" model.
2. is there any difference in video quality if i see only original video dvd
movie with and without graphics card. i wont play any game.
3. is there any way of saving webpages. other than saving it in html format,
as it saves in forder and a other file. its difficult to open. many images also
not opens. the .mht format is also not opens many time. i expect any free
software.
thaks lot.
pravinbv is offline
Old 26-08-2007, 10:55 AM   #2 (permalink)
dOm1naTOr's Avatar
Default Re: many questions. plz answer.
2.It plays .m4a which uses aac codecs. It dun support some aac formats like loseless aac etc.
3.connect the headphone and then remove the silent mode by pressinf the # for some time. U shud do it while the earpluge connected.
5. U can sent group messages to every friends simultaneously.
PC
1. Ur mobo supports only upto DDR 400
2. If u are using some gud player like Power DVD7 , then it makes use of pure video decoder when h/w acceleration is enabled. It works with some discs only[which supports h/w acceleration].
3. Use opera and select save full pages including images etc. But there wud a a file nd a folder but ull surelly get every images too.
G3: XPS M1530 |
FZ 16.
dOm1naTOr is offline
Old 26-08-2007, 11:20 AM   #3 (permalink)
swatkat's Avatar
software.
thaks lot.
You could give a try to Offline Explorer:
http://www.metaproducts.com/OE.html
http://swatrant.blogspot.com/
swatkat is offline
my two questions please answer jatt QnA (read only) 4 13-03-2007 10:53 AM
PLEASE answer my 8 questions regarding mobile phones ------- dead Mobiles and Tablets 3 25-02-2006 11:54 AM
PLease help me answer these simple questions KoRn QnA (read only) 8 16-09-2005 12:04 AM
CAN ANYONE ANSWER THESE QUESTIONS wizrulz QnA (read only) 10 07-05-2005 04:54 PM
