i think ujjwal was correct in saying that IE saves the bare html file and no the layout as it is on the web and the pics also (thru Frontpage)
also , for a couple of saved html pages i had 2 do as ujjwal said
i had to first save the page with offline explorer enterprise
then export it to my hard disk
and then save the images that werent saved in the correct folder and also replace the url in the html doc with the filename and address on my hard disk
but such a task is very large and time consuming as compared to simply saving the page with IE as it usually happens
as ujjwal said
Maybe IE is not able to save the pictures, as they are located on an external site (the top banner & the mobile phone).
can something be done about that using maybe some plugin or patch or wotever???
plz help guys
this forum is supposed 2 be full of tecchies
