Originally Posted by SmoothCriminal
aaha.. who said dat ur site wont be cached by Search engines? Dude.. its an altogether diff process.
To disable HotLinking you need to edit ur .htaccess.. and just allow access to "image" files (.gif, .jpg) etc to sites like google etc.. so its very flexible and u can choose which all sites to allow.. and which all u dont wanna allow..
So, in short its really ridiculous to say dat preventing hotlinking affects PR..
actually if the person who is smart will still be enable to display images using google as referrer...
for example..
if you allow images for say google...
so your images will be displayed in google and the source of the image will be...
http://images.google.com/images?q=tb....com/image.gif
so smart person will put the same source in his page too and since the referer is google so image will be displayed
now coming back to the main question...
Originally Posted by tuxian
Now the question is if I enable it though it will help me solve the bandwidth stealing issue but are there any disadvantages to it?
yes it will save the bandwidth for sure but enable only if someone is already stealing your images..otherwise no need to enable it...
or anyways if you want to enable it then do it..no harm in it...
cheers
Deep
