Advanced File Organizer
Advanced File Organizer is a cataloger for all kinds of media are recognized by your Windows system as drives. This includes diskettes, hard disks, CDs, DVDs, Memory Stick cards and other storage devices. Advanced File Organizer can be your DVD organizer or CD organizer, if you want. It helps to create a catalog of your disk collection. This catalog will help you easily find all necessary files and folders without the need to insert any disks into the drive.
Advanced File Organizer makes it easy to:- Arrange files from all disks into handy custom categories.
- Organize the hierarchy of categories (Category Tree).
- Browse files and folders in two ways: according to categories and according to physical location.
- Add your own comments to every category, file, folder or disk.
- Make all of the above even easier with:
- A special service for scanning disks.
- A tool for exporting the category tree (simply export the category tree, edit it or use "as is" for sorting out other data).
- Search for files and folders.
- Make reports and print all information from your catalog.
- Update file, folder, and disk information at any time.
- Sort files, folders, disks and categories by attributes, names, locations, creation date, types of files etc.
Note
Advanced File Organizer does not use any database engines. The database generated by Advanced File Organizer is very compact and will be fully compatible with future versions. And last but not least, Advanced File Organizer looks just as great as it works!
© Copyright 2000-2005,
SoftPrime Development
