Old 23-08-2007, 12:12 PM   #1 (permalink)
Traceur
zegulas's Avatar
Exclamation Why do I get this error?
Temp2.exe- Application error
the instruction at "0x0040126e"
reffered memory at "0x0000000c"
The memory could not be read.
I get this error message while windows is starting up.
Parkour: A journey started by two & followed by many...
zegulas is offline
Old 23-08-2007, 12:21 PM   #2 (permalink)
Rebooting
Choto Cheeta's Avatar
Default Re: Why do I get this error?
Warning
You may have Virus or Spyware under your system... Install Spybot SnD update and run a full scan for Spyware...
also use a better Antivirus such as Kaspersky or NOD32
you may try Kaspersky free online scanner, http://www.kaspersky.com/virusscanner to check if any Virus under your System..
Note when you run any scan, keep you system restore turned off...
rebooting
ChotoCheeta.com
Choto Cheeta is offline
Splinter Cell:Double Agent Visual C++ runtime error and ***MUST CHECK*** error zerohourkill Gamerz 17 04-08-2007 02:47 PM
Windows XP Booting and Installation Error (LILO Error) arijitraja Software Q&A 3 26-02-2006 03:32 PM
error while trying to retrive text for error ORA-12203 vikasg03 Software Q&A 1 14-11-2005 02:48 PM
Error error error....gives me hell of a terror abhilash QnA (read only) 4 06-11-2004 12:41 AM
