Old 22-08-2007, 08:36 AM   #1 (permalink)
Anindya's Avatar
Question Folder option gone!
I cant find The Folder Option under the Tools menu. Plz help me restore it. Thanks
www.techani.com
Latest post ->Take Ur Applications & Personal Settings With You
->Umpires Are Vampires
The Most Unknolegeble Parson. Plese Tech Me.
Anindya is offline
Old 22-08-2007, 08:41 AM   #2 (permalink)
dig_boy_dig,dig !
skghosh44's Avatar
Default Re: Folder option gone!
Please go through this thread.
No Folder Option
and
http://www.myfixes.com/quickfixes/fixes/24
I think with the help of those you can solve your problem
________________________________________________
I like signature after 10 P.M.
skghosh44 is offline
Old 22-08-2007, 08:57 AM   #3 (permalink)
Anindya's Avatar
Thanks ghosh!!
www.techani.com
Anindya is offline
Old 22-08-2007, 11:04 AM   #4 (permalink)
sharma_atul85's Avatar
following link works only if u r using win xp pro
run gpedit.msc
admin tools(last option)
windows xplorer
there vil b an option to show folder option
hope it ll work
sharma_atul85 is offline
Old 22-08-2007, 11:19 AM   #5 (permalink)
Ron
||uLtiMaTE WinNER||
Ron's Avatar
It may be due to virus...........
And hey buudy....Search Before U post......
And hey buudy....There are many threads related to it........Search Before U post......
And hey buudy....There are many threads related to it........Try to Search( If possible) .....Before U post......
||uLtiMaTE WinNER||
Ron is offline
Old 22-08-2007, 11:25 AM   #6 (permalink)
Ankush_is_here's Avatar
Dont worry bro just make new user profile in control pannel
Ankush_is_here is offline
Old 08-09-2007, 12:27 AM   #7 (permalink)
Thumbs up Re: Folder option gone!
This video is step by step tutorial to solve your problem of folder option missing
http://www.metacafe.com/watch/807588...ption_missing/
if it is helpful to you plz rate it 5
thank you..
max_019 is offline
Old 10-09-2007, 01:18 PM   #8 (permalink)
Use Anti Brontok
`·.¸(¨`·.·´¨)Keep
(¨`·.·´¨)¸.·´ Smiling!
`·.¸.·´ Ankush Gupta
Mycomputer - tools - folder option??? no folder option jayanbhm QnA (read only) 19 21-05-2007 02:43 PM
No Folder Option shakshy Software Q&A 10 13-12-2006 02:21 PM
Where is the Folder option? debiprasad_sahoo Software Q&A 7 26-10-2006 10:34 AM
How to Remove Hide Option Frm Folder Option Chindi_Chor QnA (read only) 17 23-03-2006 11:18 PM
about the folder option pravesh_4766 QnA (read only) 2 03-04-2005 08:56 AM
