Old 08-03-2005, 05:22 PM   #1 (permalink)
The Hardware Labs
mohit's Avatar
Default pc gets stuck help......
hey guyz i am using a p4 2.8 ghz , 512 ram wid win xp sp 2 . i use a reliance fwp for connecting to the net . i was fiddling around wid the services n registry tweaks using REGSEEKER and now i am facing a problem. whenever i connect to the internet my pc stops responding for a few minutes. it doesnt hang though , it just gets stuck and i am not able to launch any programs meanwhile and even explorer doesnt open. after around 2 mins it becomes normal and things work perfectly, all the things i clicked on before it got stuck open up at once after 2 mins. somebody help me with this . i have tried everything including restoring my registry and also reinstalling my reliance phone, etc but it still doesnt work. plz help.
mohit is offline
Old 08-03-2005, 11:58 PM   #2 (permalink)
hafees's Avatar
Ooops... try stopping all the unnecessary processes using task manager. or try using a spyware removal tool. or try connecting the reliance phone to a different com port. ( i really dont know what went wrong... do any one have an idea??)
hafees is offline
Old 09-03-2005, 12:16 AM   #3 (permalink)
Thats strange man.
But I think I know the answer.
It might be because of the slow initial connection speed. It happens sometimes that the connection speed decreases & the byte transfer rate dastically reduces. So the net becomes tremendously slow resulting in those problems.
However it may also be due to some Spyware.
It should not be a registry problem as u said that restoring ur reg. did not work.
suj_engico is offline
Old 09-03-2005, 12:20 AM   #4 (permalink)
if you're sure that you have f*cked up the registry then use system restore and roll back to a prior date.
daj123 is offline
Old 09-03-2005, 11:34 AM   #5 (permalink)
The Hardware Labs
mohit's Avatar
Default my system is damn secure ..
I am not having any spyware installed. I am using MS Antispyware and kaspersky anti virus n firewall . and no the net is also not slow i get good speeds. and the most unfortunate part is i had disabled system restore. it is just dat my comp seems to be out of ram or something and it happens only when i get online. got any more suggestions ?
mohit is offline
