08-03-2005, 03:01 PM
My Configuration Is.........!!! HelP
Yes my config.. is intel 1.6~ Ghz, Mercury Motherboard KOB845NFSX, 128 SD ram, 32 mb SiS graphics card..
Now I want to upgrade my ram and graphics card to 512 ram and 64 or 128 graphics card. I want to ask u guys that will my pc support the new things.
Please tell
08-03-2005, 04:14 PM
u r @ the wrong place dude !
try the hardware section
C2D@ 2.4Ghz,Asus P5B Dlx,2X1GB Kingston@677 Mhz,Viewsonic 20",Sparkle 7200 GS ,SB Live Audigy on Creative Inspire T7900,Leadtek WinFast XP TV Tuner,Storage :Seagate 320GB + WD My Notebook 1TB
08-03-2005, 04:50 PM
yeah..u can upgrade to 512mb ram....r u having SiS Graphics Card with u now?, u can put a newer card.....
http://swatrant.blogspot.com/
08-03-2005, 06:16 PM
thanks, Yes i have.., but I am upgrading it in this summer. Also I want to know that with this new configuration can I able to play Half life 2 smoothly
08-03-2005, 06:20 PM
Also tell...best graphics card for half life 2........ budget--- between 9000-10,000 8)
08-03-2005, 06:57 PM
ATI Radeon 9600 PRO
Incompatible message format
09-03-2005, 01:00 AM
I doubt the 845 based mobo will have an AGP slot or if it does it will have a 4x AGP slot. You need a 8X slot for an Ati radeon 9600/9800 PRO.
10-03-2005, 03:03 PM
Thanks I will ask my dady 8)
bye
10-03-2005, 04:50 PM
No u dont need a 8X slot. Even a 4X slot would do. The 8X card will just run at 4X and there isnt much of an improvement between 4x and 8X anyways.
AMD 64 3500+ Venice
DFI Lan Party Ultra-D
XFX 7900GT 256 MB Card
10-03-2005, 05:20 PM
Here's my mothereboard info:
Description
- Pentium 4 Mainboard with Intel 845 Chipset Design
Processors
- Socket 478 supports the
* Intel Pentium 4 processor (Northwood)
Chipset
- Intel 82845 & 82801BA--Memory Controller Hub (MCH), I/O Controller Hub 2 (ICH2) & Firmware Hub (FWH) with following features:
* Supports 4X AGP (AGP 2.0 Specification), 1.5V only
* Supports Ultra DMA100 (ATA100)
- LPC I/O: ITE 8712F
- AC97 Audio Codec
* Compliant with AC97 2.2 specification
System BIOS
- Award BIOS with Flash ROM in Firmware Hub (FWH)
- Supports Plug and Play 1.0A, APM 1.2, Multi Boot, DMI
- Full support for ACPI revision 1.0A specification
Memory
- Three 168-pin DIMM sockets for 3.3V SDRAM (PC133/PC100)
- Maximum: 3GB
I/O Interface
- Supports Plug and Play function
- PS/2 keyboard and PS/2 mouse connectors
- Dual USB Ports and LAN Connector
- One - EPP/ECP mode parallel port
- Two - 16550 high-speed serial I/O ports
- Audio Ports (Line-in, Line-out, Mic-in, CD-in and game port)
- Supports 360K~2.88M Byte, 3 Mode FDDs or LS120
- Dual PCI IDE interfaces - support four IDE devices (PIO mode 4, DMA Mode 2, Ultra DMA66/100)
- ATX12V Power Supply Connectors
- Ports, headers and others
* IrDA header
* Extra USB header
* Front Panel MIC/Line-Out header
* Chassis open detector header
* HDD LED, ACPI MSG LED, Reset Switch, Power Switch headers
* CPU, Case and Power Supply Fan headers
* LAN Card Wake Up/Internal Modem Ring Wake-Up headers
RTC & Battery
- Intel I/O Controller Hub 2 (ICH2) included 256 bytes CMOS SRAM
- With CMOS SRAM hardware clear jumper
Expansion Slots
- 6PCI slots, 1 AGP Slot, 1 CNR Slot
Form Factor & Layers
- ATX Size (304mm x 244mm), 4 Layers
I would not be buying new motherboard so tell other products to boost gaming region. Since mine is 1.6Ghz
10-03-2005, 06:39 PM
Ignorance is BLISS !!
There is a place on this forum for Hardware!
Please post it there for better results !
10-03-2005, 07:05 PM
that report saya it all....
u can put upto 3GB of RAM (SDRAM of 133MHz speed) , and yes u can put an AGP 8X card in an AGP 4X slot, no problems.....
go for Radeon 9600 pro or 9800 AGP Card.....
u have 3 RAM slots, and now u have 128MB RAM, upgrade to atleast 512MB Total RAM.....
11-03-2005, 12:40 PM
Great thankz
11-03-2005, 12:51 PM
hey how much 8x card will cost and radeon, 9800 AGP card.
Which is better for gaming
11-03-2005, 10:07 PM
Hey remeber SD RAMs today cost a bomb and prices going up every day. A few weeks back i enquired the rates were 2000 for 128 MB SD RAM and 4K for 256.
Pls dont delay ur ram upgrade. Do it as soon as possible
Have a Nice Day :)
Mohammed Muchhala, © 2006, All Rights Reserved
http://www.muchhalasworld.com
11-03-2005, 10:25 PM
I am asking for graphics crad prices !!! In todays days........
11-03-2005, 11:08 PM
9800 non pro will cost you above 10K. The 9600 pro will cost you around 8K. So its upto u.
AMD 64 3500+ Venice
Search this Thread |
