Old 08-03-2005, 01:08 PM   #1 (permalink)
Default How to stop scandisk at startup?
How can i stop scandisk from running at startup in windows XP? There is no option under msconfig. Also tell me what is hibernate function and how to use it?.
Antec Cabinet, P4 2.8 ghz (HT), Sony Dvd Rom, XFX 5600 U, MSi 875 Neo2, 80 GB Seagate Barracuda 7200 RPM, Creative SB live 5.1, Creative Inspire 4.1 4400, Corsair 512 MB DDR
Delpiero is offline
Old 08-03-2005, 01:49 PM   #2 (permalink)
vysakh's Avatar
to use hibernate function, you need to enable it first.
to enable hibernation, go to control panel--->power options ---->hibernate----->enable hibernation.
to hibernate, go to start, turn off. In the confirming window, press shift. You will notice that the standby icon changes to hibernate. click it to hibernate.
Incompatible message format
vysakh is offline
Old 08-03-2005, 01:51 PM   #3 (permalink)
vysakh's Avatar
you must shut down your system properly everytime using start-->turn off ---->shutdown. then there wont be scandisk.
if you cancel the scandisk one time, it will automatically come the next time you boot into XP. so dont avoid scan disks. if you cancelled it then in type chkdsk in start-->run and execute it.
vysakh is offline
Old 08-03-2005, 02:10 PM   #4 (permalink)
swatkat's Avatar
do this, Go to Start>Run and type cmd and press Enter.
At Command Prompt, type CHKNTFS /D and pess Enter.
Here there is a SPACE between CHKNTFS and /D, and u have type /D only and D means Default (not D: DRive).
After u run this command, u REBOOT the PC, here XP should scan the Disks one time (DONT CANCEL), after this u will not get the chkdsk again at startup....
http://swatrant.blogspot.com/
swatkat is offline
