Old 08-03-2005, 10:06 AM   #1 (permalink)
Default "Ntldr is missing"
I have winXP in my computer. when i boot my computer it gives such message. how to clear it?
Hey I am cool..........
kamaal is offline
Old 08-03-2005, 10:27 AM   #2 (permalink)
hi m8, u just corrupted ur MBR.restart once ..if ur problem persists,use a bootable winxp cd to repair xp
http://www.computerhope.com/issues/ch000465.htm
C2D@ 2.4Ghz,Asus P5B Dlx,2X1GB Kingston@677 Mhz,Viewsonic 20",Sparkle 7200 GS ,SB Live Audigy on Creative Inspire T7900,Leadtek WinFast XP TV Tuner,Storage :Seagate 320GB + WD My Notebook 1TB
blacklight is offline
Old 10-03-2005, 10:54 PM   #3 (permalink)
Default Re
Use WinXP boot disc to repair or reinstall WinXP
bye
ganesh_dabhade is offline
Old 10-03-2005, 11:14 PM   #4 (permalink)
Try to run rescue from boot cd..as suggested by blacklight
ntldr is xp boot loader as far as i know ... also ntldr.com and some dir called sys volume info..all these are considered important files and also hal.dll is a importnant file during boot
h4xbox is offline
Old 10-03-2005, 11:18 PM   #5 (permalink)
boot from cd and repair and replace the missing file
Stay cool always!!!
cool_techie is offline
Old 11-03-2005, 01:24 PM   #6 (permalink)
club_pranay's Avatar
replace the file from the Xp install CD to the root folder
this will solve the problem
and please serach the forum, a lot of topics on this prob already posted!!
Be not Thou far from me o Lord....o my strength....haste Thee to help me.
club_pranay is offline
Old 11-03-2005, 01:57 PM   #7 (permalink)
Ignorance is BLISS !!
Get ur bootable CD running in Rescue mode and then repair the file (extract the file from the cd and restore it)
rajkumar_personal is offline
Old 11-03-2005, 05:32 PM   #8 (permalink)
these guys are partially right
boot from ur winxp cd
goto the recovery console
and run fixboot and fixmbr commands at the prompt !
that should fix it
No Mercy, No Limits.
theraven is offline
Old 12-03-2005, 06:07 PM   #9 (permalink)
Can anybody tell me how to solve this problem without using boot cd ?. Tricky perhaps.
Antec Cabinet, P4 2.8 ghz (HT), Sony Dvd Rom, XFX 5600 U, MSi 875 Neo2, 80 GB Seagate Barracuda 7200 RPM, Creative SB live 5.1, Creative Inspire 4.1 4400, Corsair 512 MB DDR
Delpiero is offline
Old 12-03-2005, 06:16 PM   #10 (permalink)
enoonmai's Avatar
Yeah, you could probably copy the files in the i386 folder into the hard disk, and then use the winnt32 file to install the Recovery Console as a startup option and then go into the recovery console and run the commands theraven said. Works without a boot CD all right.
Playing FEAR XP/LSW2
enoonmai is offline
