Old 07-03-2005, 11:49 PM   #1 (permalink)
Default SKIP DOCTOR
I recently read about a new electronic gadget which I thought I should share it with you.
It is known as the SKIP DOCTOR.It is an electrically operated device which helps you to repair scratched cds.
The skip doctor CD RESTORER repairs abrasions and light,medium and even deeper scratches on cds and is incredibly easy to use.
Place your disc inthe slot provided,spray it with resurfacing fluid and slide the disc into the guiding track.Than switch the device on.The rest is done by the SKIP DOCTOR.After 2 full rotations your cd is compltely restored.
Deva is offline
Old 08-03-2005, 12:34 AM   #2 (permalink)
Hey Man
where did you read about that???
If u are planning to buy that i have a bundle of scratched CDs.
psappuin is offline
Old 08-03-2005, 05:11 AM   #3 (permalink)
thats a gud device... lol will be using less toothpaste ater all!!!
grinning_devil is offline
Old 08-03-2005, 08:12 AM   #4 (permalink)
hack expert's Avatar
man dat would really be cool is it available in indian markets
hey can u do something just give link to the place where u have read dat
If electricty comes from electrons, does morality come from morons?
Flying is simple. You just throw yourself at the ground and miss
hack expert is offline
Old 08-03-2005, 10:46 AM   #5 (permalink)
vysakh's Avatar
what about the price ?
and did u try it ?
Incompatible message format
vysakh is offline
Old 08-03-2005, 11:48 PM   #6 (permalink)
I read this article in the local newspaper.So i cant provide u any link.I will try to find about the prices and post later.
[/quote]
Deva is offline
Old 08-03-2005, 11:52 PM   #7 (permalink)
toothpaste helps clean cdroms ??????????? ok which brand , flavour and how much to use ???
If you make yourself more than just a man, if you devote yourself to an ideal... You become something else entirely
klinux is offline
Old 09-03-2005, 12:21 AM   #8 (permalink)
local newspaper!!
i hope your gadget is not as local as ur paper
tell me the name of that newspaper???????
neet_online is offline
Old 09-03-2005, 01:15 AM   #9 (permalink)
neet_online......... Get ur basics clear.
The data is stored on the reverse side of the CD. I mean the scratch is just a barrier between the drive read system and the data. U c... there is a covering over ur written data from the top above which the cd is branded. Ig u attempt to write nething on it in pen then it would rip thro' the covering and all ur silver plating wud rip off. This is the section where ur data is stored.
Now when u insert the CD the data is read from below surface. If there r scratches on it.... it means u just cannot access the data. As simple as dat. If u can find nething that wil restore the cracks...bravo!!! U have just done it.
As far as wat Deva introduces here... hvn't heard of it but if it exists it shud b costly for sure. But worth a buy smtimes. Deve pls post bak soon wid updated details.
Ish Karo... Ishq karna Tumhara Paidaishi Haq Hai........
Magar Kyon Na Is Bar Watan Ki Mitti Ko Mashuka bana le!!!
http://www.aseemn.org
Aseem Nasnodkar is offline
Old 09-03-2005, 10:40 AM   #10 (permalink)
u never tried it...is it????
apply a layer of toothpaste on a scratched cd,then clean it off with a cloth,nd try to run the cd....this procedure works around 80% for me...
i think toothpaste acts like a reflective material nd fills the scrathes....just a guess though.....
was able to copy sum movies this way ....
Old 10-03-2005, 08:21 PM   #11 (permalink)
wow..wat a tip..its indeed new news to me.. so finally toothpaste is useful somwhere huh!
bluediamond is offline
