Old 17-08-2007, 10:15 AM   #1 (permalink)
Default Disk Cleanup
Hi,
when I ran disk cleanup utility in windows XP, it shows one option..
catalog files for the content indexer.. If i chose this options, it will delete
important folder such as I have downloded or any other folder which should not be deleted. By default this option is selected. If by mistake I continue with cleanup ,, it will delete that important folder. How can I remove this option from diskcleanup utility permanently.. Thanks for your advice..
shersaha is offline
Old 20-08-2007, 12:25 AM   #2 (permalink)
Default Re: Disk Cleanup
Is there any body please help..
shersaha is offline
Old 22-08-2007, 01:39 PM   #3 (permalink)
Distinguished Member
anandk's Avatar
These Catalog files remain from a previous indexing operation and can be deleted safely.
http://support.microsoft.com/default.aspx/kb/315246
> www.TheWindowsClub.com <
= www.WinVistaClub.com =
Microsoft® MVP
anandk is offline
Forcing Windows XP's Disk Cleanup to delete all temporary files morpheusv6 Tutorials 1 06-05-2007 08:46 AM
The 'Hidden' Enhanced Disk Cleanup Tool in Windows Vista anandk Tutorials 6 10-04-2007 01:48 AM
Forcing Windows XP's Disk Cleanup to delete all temporary files anandk Tutorials 2 08-04-2007 07:35 PM
The Windows Installer CleanUp Utility. anandk Software Q&A 4 24-11-2005 07:29 PM
Help with cleanup!!! mario_pant QnA (read only) 5 31-03-2005 06:50 PM
