Old 17-08-2007, 01:50 AM   #1 (permalink)
bajaj151's Avatar
Default Price ?
I am planning to buy some stuff for my case modding....such as
1) Neon tubelights
2) Sleeves for my IDE cables
Suggest me any other thing to buy for my wires inside cabinet to look COOL....
Problems & Suggestion
1) Is neon lights generate lot of heat ????
2) Suggest sleeves to go for...
Also tell me the shop in Nehru place & their approx price....
Phenom x6 1055T 3.75 GHz | MSI 890GXM G65 | Corsair XMS3 2*4GB 1600mhz | BenQ E2200HD | Xbox 360 Controller | Seagate 2TB | CM HAF 922 | Corsair VX 550 | Logitech MX 518 | Logitech Wireless Keyboard | Sapphire 7850 OC
bajaj151 is online now
Old 24-09-2007, 12:54 PM   #2 (permalink)
bajaj151's Avatar
Default Re: Price ?
Is it available in Nehru Place ??
Old 26-09-2007, 11:56 AM   #3 (permalink)
bajaj151's Avatar
Default Re: Price ?
k...I think....my digitians not intersted in answering.....
Old 26-09-2007, 12:13 PM   #4 (permalink)
din
Tribal Boy
din's Avatar
Default Re: Price ?
Digit guys always love helping others
But when you post something, always remember to give some meaningful topic title.
When you make " Price ?" as the topic title, most people will not know what price you meant.
Instead, use something like "Price for Neon tubelights /
Sleeves for my IDE cables ?" -
Then people who browse the forum will know whats your question before reading the thread.
The thread title always matter.
din is offline
Old 26-09-2007, 02:06 PM   #5 (permalink)
Cool G5's Avatar
Default Re: Price ?
Ya Digit forum members always are there to help you.
U can get a rounded ide cables as suggested in Digit.It looks cool & also results in heat dissipation.I think they mentioned some Rs.500 for it.Don't know exactly.
Neon light won't add much heat.
Before you do the modding,clean the case thoroughly & the components.After that make sure to use good fans for ventilation.Fix one fan on top,preferably a big one.
Hope this helps.
Cool G5 is offline
Old 26-09-2007, 03:40 PM   #6 (permalink)
bajaj151's Avatar
Default Re: Price ?
ok bro.......thnx ...
and I am sorry for my mistake regarding appropriate title.....
Hope this helps.
Is rounded cables available in Nehru place..If yes...could you plz confirm the shop......
Presently...I am using Zebronics Antibiotic Cabinet......So..I think....neon light wont affect lighting...much more.........so..I shud buy sleeves only....which solves both my purpose of controlling proper airflow as well as heat...
Old 26-09-2007, 04:12 PM   #7 (permalink)
Cool G5's Avatar
Default Re: Price ?
^I stay in Mumbai buddy.
Cool G5 is offline
Old 26-09-2007, 06:25 PM   #8 (permalink)
bajaj151's Avatar
Default Re: Price ?
okiezz....
Price no bar - which is better? koolbluez Mobiles and Tablets 8 30-12-2006 05:28 PM
Tell Me The Price Of My Rig ! sidewinder QnA (read only) 5 27-03-2006 12:06 AM
cd price ? shreyadr QnA (read only) 20 15-06-2005 10:00 AM
AMD price = pentium3.0ghzHT price ? Shreekant CPU / Motherboards 21 21-05-2005 12:07 AM
