Old 16-08-2007, 11:41 PM   #1 (permalink)
Pragadheesh's Avatar
Unhappy "Show hidden files and folders" button is missing
hi, all of a sudden the "Show hidden files and folders" button is missing from the tools-folder options-view menu..
here is an image of how it looks..
so if any one by mistake clicks "Do not show hidden files and folders" and clicks OK the i cant view the hidden files..
help me in bringing it back...
Pragadheesh is offline
Old 16-08-2007, 11:51 PM   #2 (permalink)
slugger's Avatar
Default Re: "Show hidden files and folders" button is missing
find dis key in registry
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\Advanced\Folder\Hidden
modify d value data of Type to group
and u will c d unseen
slugger is offline
Old 17-08-2007, 11:16 PM   #3 (permalink)
Post Re: "Show hidden files and folders" button is missing
i have tried it but still not working... any other method.. plz help.....
Old 17-08-2007, 11:47 PM   #4 (permalink)
hansraj's Avatar
try the universal system restore... it should work
hansraj is offline
Old 18-08-2007, 12:04 AM   #5 (permalink)
slugger's Avatar
u sure u ver unable 2 get dat button back
did u find d key dat i had asked 2 find
and den did u find d value Type
did u double click on it and den wen d win opens up did u type ingroup
and save it
if need log off and den log back in
if it still does not help u can enable show hidden files and folders from here
 HKEY_CURRENT_USER\Software\Microsoft\ Windows\CurrentVersion\Explorer\Advanced
in d right side u will find u will find d key hidden double click on it and in d win dat opens up change d value to 1
hope dis helps
also it seems dat ur computer is infected, run a good anti-virus scan like kaspersky or avast
slugger is offline
Old 18-08-2007, 11:19 PM   #6 (permalink)
thanx for yo reply.. but still didnt work out... tried both the reg edit stuffs.. everything is fine.. also i'm using kaspersky 7.0 which s up to date...
Old 19-08-2007, 06:12 AM   #7 (permalink)
virus_killer's Avatar
Follow this buddy -> not showing hidden folders
Source: VG
Device: T-Mobile G1(black)
ROM: JF ADP1.5 Apps2sd
104 apps with 69 MB remaining
virus_killer is offline
VISTA TUTORIAL: Add "Hide File Names" Option in "View" Menu of Folders Vishal Gupta Tutorials 7 27-06-2007 10:46 PM
TUTORIAL: Effective Way to change the "start" button text in Windows XP Kiran.dks Tutorials 20 14-03-2007 03:41 PM
"INF Error", VGA Driver "Missing" Installing ATI Catalyst Drivers CannedLizard Hardware Q&A 4 29-07-2006 12:47 AM
lost my "show desktop "quick launch button go_gamez Software Q&A 5 29-06-2006 12:21 AM
deactivate "show hidden folders" joshy QnA (read only) 7 23-12-2005 09:16 PM
