Old 15-08-2007, 11:24 PM   #1 (permalink)
User Name's Avatar
Default Partition without lossing data
Hi
my pc hav two 20 GB partition.
Is it possible to merge both partition into one of 40 GB without lossing my data?
User Name is offline
Old 16-08-2007, 12:01 AM   #2 (permalink)
TechTin.com
ravi_9793's Avatar
Default Re: Partition without lossing data
I dont think it is posiible...however you can give a try to magic partition.
ravi_9793 is offline
Old 16-08-2007, 12:27 AM   #3 (permalink)
slugger's Avatar
partiton magic does claim to b able to do wat u want but it is always better 2 back up data b4 venturing out 2 do this
slugger is offline
Old 16-08-2007, 12:35 AM   #4 (permalink)
try paragon partition manager, its better than partition magic.
I once lost data while merging two drives but was never a case in paragon partition manage.
Faun is offline
Old 16-08-2007, 12:53 AM   #5 (permalink)
merging ur partition the data will be copied, I often do it & have never lost it............but there is no harm in taking a back up, so I use "trueimage" for making a back up.
ranjan2001 is offline
Old 16-08-2007, 11:05 PM   #6 (permalink)
Pragadheesh's Avatar
Post Re: Partition without lossing data
try using partition magic... but its better u back up the data... b'coz by chance , once lost then its useless crying over spilt milk..
Pragadheesh is offline
Old 16-08-2007, 11:48 PM   #7 (permalink)
User Name's Avatar
@ranjan2001
Can u explain in detail.
Pragadheesh
I don't hav enough space for back up the data.
Old 16-08-2007, 11:52 PM   #8 (permalink)
Alive Again...
satyamy's Avatar
it is possible
many softwares like partition magic do this but it is risky, so do it at ur own risk
! जय हिंद ! Proud to be INDIAN
satyamy is offline
Old 17-08-2007, 12:38 AM   #9 (permalink)
sauravktr's Avatar
Acronis Partition Manager
" 99% computer Problems are between the PC & the CHAIR "
sauravktr is offline
Old 17-08-2007, 10:40 AM   #10 (permalink)
There is not much detail in this, its simple procedure, when using Partition magic it will ask u to choose the partition to merge, then what it does is that it removes the logical partition & moves the data to another area of the disk.
Points to remember is that u should have 20% free space at least & u should have good power backup for 20 mins, if there is power failure then u will be messed up, hence its said to have a data backup.
I dont need to take backup as I have 30mins backup on APC ups but since its important data I take the backup using arconis true image.
What Softwares/techniques data recovery professional use to recover data from HDD ? CadCrazy Software Q&A 1 10-08-2007 10:01 AM
Save me! I m lossing my hairs. ~~no open/can`t open~~ CA50 Hardware Q&A 16 14-07-2007 09:15 PM
data in partition, not shown in windows, y? legolas Open Source 14 19-08-2006 01:20 PM
LOST PARTITION ! URGENT HELP IN DATA RECOVERY NEEDED !!!!!! arnold Software Q&A 4 20-10-2005 02:04 PM
