Would it be possible to add more file when your trying to burn an iso file onto a disc? I mean like if the source is an iso file can i add more stuff to burn along with the iso file. If yes please guide. Thanks!
Depends ! If the source is non-bootable Data then one can extract using softwares like isobuster, magicIso etc and then add the needed files and convert it to the iso file.
For bootable iso you have to maintain the structure of the boot sector by extracting the files first , then adding needed files and then adding boot sector again to make the iso image.
Is u can, try MagicISO (Paid software) but if the source is a bootable ISO, may give u problem while comiling, so before u work with a Bootable ISO< extract the boot image, so when u pack the ISO once again, u can use that Boot image to restore its bootable functions
Re: IS this possible?
easily.. provided the file is not already full to cd/dvd limits... ie.. 700mb or 4.2+GB
MagicISO.. UltraISO... WinISO.. all & more do it.
