Old 07-03-2005, 03:30 PM   #1 (permalink)
Default give me reply?
what is difference betn www.something.com and something.com?
i m confused about much when im tryin both thwy work as same...
can ne1 give me the answer........
If you want the best, you have to vote for the best
V.I.P.U.L.:= Vigilant Individual Programmed for Ultimate Learning
vipul is offline
Old 07-03-2005, 03:39 PM   #2 (permalink)
no difference...they both access the same domain. So thats why you see same pages.
AMD 64 3500+ Venice
DFI Lan Party Ultra-D
XFX 7900GT 256 MB Card
icecoolz is offline
Old 07-03-2005, 03:50 PM   #3 (permalink)
Another Brick in the Wall
drgrudge's Avatar
It works, beacuse the browsers fills in the http://www. for you.
Also when u press ctrl (not sure) and only "something", the it fills http://www. and .com for u as well.
drgrudge is offline
Old 07-03-2005, 03:51 PM   #4 (permalink)
but there are some sitz ware a www will not work such as
http://mail.spectranet.com
http://www.mail.spectranet.com doesnt work
as the www is not part of the address anymore and we need to go 2 da 'mail' site of spectranet.com
ishaan is offline
Old 07-03-2005, 05:31 PM   #5 (permalink)
ramprasad's Avatar
Hi
I may deviate from the topic a bit.... but I feel it is an important shortcut....
type the domain name and press "Ctrl + Enter", IE by itself fills in "http:\\www." as prefix and ".com" as suffix.
Eg.
rediff followed by "Ctrl + Enter" will take you to http:\\www.rediff.com
I think the different cases u have specified must be pointing to the different directories or services on the servers. I used to do the same thing with IIS in my personal web server....
Regards,
Ramprasad
ramprasad is offline
Old 07-03-2005, 06:25 PM   #6 (permalink)
ditto for http://www.grisoft.com (works) and http://grisoft.com (site doesn't work)
www is actually a sub-domain..
Hitesh Gupta
There are only 10 type of people in world...
1 who understand binary..
1 who don't
hitesh_hg is offline
Old 07-03-2005, 06:30 PM   #7 (permalink)
Well each domain is mapped to an IP. And its not a 1-1 relationship. Multiple domains can be mapped to multiple address. Thats why you have Domain servers. It depends if someone did register the whole domain with the www or not. Hence sometimes the "www" added part doesnt work.
AMD 64 3500+ Venice
icecoolz is offline
Old 07-03-2005, 08:09 PM   #8 (permalink)
Version 2.0
Deep's Avatar
Default Re: give me reply?
damn too weird answers here..
let me give you the correct one
www is the just the subdomain...
www is pointed to main domain because we are used to it...
you can point www to some other place also no restrictions there
take this example...
if you have domain example.com
and if you want people to see something else when they type www.example.com then you can edit the settings in configuration file and point users to some other place...say when people type www.example.com they should go to yahoo.com, you can do that...
I hope you got the answer..
Regards
Deep
- Deep Ganatra -
www.whoisdeep.com
www.twitter.com/DeepXP/
Deep is offline
Old 07-03-2005, 08:11 PM   #9 (permalink)
Version 2.0
Deep's Avatar
aah...the answer you provided is not correct
You cannot register a subdomain...
(www is subdomain is main domain..see the answer above)
Deep
- Deep Ganatra -
www.whoisdeep.com
Deep is offline
Old 08-03-2005, 11:30 AM   #10 (permalink)
tuxfan's Avatar
Now Deep truly justifies his signature Here's the new teacher
I agree with most of what he says. www surely can be made to work as a subdomain. I remember long ago there was a site called homepage.com which used to give its users a subdomain as their free sites. Some smart cookie registered www as his subdomain and for 1-2 days the site went for a toss
USUALLY you can't buy a subdomain. It is under a domain that you have. But when it comes to .in so far we had been buying subdomains under the domain name .co.in and .net.in. Only recently has the domain sell under .in TLD has started.
tuxfan is offline
Old 08-03-2005, 11:56 AM   #11 (permalink)
thanks Deep for the heads up on the info. I'll keep that in mind
AMD 64 3500+ Venice
icecoolz is offline
