Old 13-08-2007, 08:19 PM   #1 (permalink)
Red face pls help needed urgently!!!!
suddenly my keboard windows key stopped working after a software removal.
also can't open Task Manager by ctrl+alt+del key.
pls. help
bhoolkumehul is offline
Old 13-08-2007, 08:20 PM   #2 (permalink)
The Internationalist
Aberforth's Avatar
Default Re: pls help needed urgently!!!!
Can you name the software?
Aberforth is offline
Old 13-08-2007, 08:25 PM   #3 (permalink)
sam_1710's Avatar
Alternatively you may use Ctrl+Shift+Esc to invoke the task manager!!
C2D E8400, MSI P45 Neo-F, Sapphire HD4850, Dell 2409W, OCZ 2*1GB RAM + 1*2GB Transcend + 1*1GB Transcend , Seagate 1TB + 2*Seagate 80GB, 600W SMPS, APC 600VA, Creative EP630, Sennheiser HD202 :)
sam_1710 is offline
Old 13-08-2007, 08:32 PM   #4 (permalink)
i think ctrl and windows keys are not working.
i unistallled Ad-Aware 2007 free edition.
i tried word pad wrote somthing than select all than tried to copy with ctrl+c but no repsonce and only word "c" written.
Old 14-08-2007, 08:13 AM   #5 (permalink)
Gracias Senor
dreams's Avatar
Guys..for me too the ctrl key is not working..esp Ctrl+c and Ctrl+v.
I am not sure when this occurred..I even cleaned my keyboard of no use..
any ideaz???
iPT 2G(S) - 8GB - JBn
iPhone 3GS 16GB - JBn
MAC OSx86 on P4 2.4Ghz
HTC Touch - Elfin - P3452 - WM 6.5
- Dont Dre@m... Juz Chase it -
dreams is offline
Old 14-08-2007, 01:24 PM   #6 (permalink)
ax3
Cool as a CUCUMBAR ! ! !
ax3's Avatar
try pressing those key`s firmly ....... my kb has problem 2 ......... when i press more or try pressing cross keys it works ...........
try installing drivers again ...........
... W H O T ...
ax3 is offline
Old 14-08-2007, 03:57 PM   #7 (permalink)
slugger's Avatar
any ideaz???
sinc u mention esp duz it mean dat other shortcuts involving ctrl work?
like
CTRL+ESC
CTRL+X
CTRL+Z
CTRL+B
CTRL+U
CTRL+I
if none of them work then it definitely means dat ur ctrl key is givin up
did u clean it after dismantelin d whole keyboard
if not den as a last measure u might wan 2 dismantle d keyboard, check 4 d alignment of d rubber membrane underneath, also d alignment of d circuit undernaeth d membrane 2 ensure dat wen u press d ctrl key it is makin proper contact wit d proper location in d circuit or not
slugger is offline
Old 14-08-2007, 04:04 PM   #8 (permalink)
Wire muncher!
infra_red_dude's Avatar
check if the the default keyboard layout was changed before dismantling the hardware. check a different keyboard on ur system. that will help ascertain where is the problem.
infra_red_dude is offline
Help needed urgently. 144 QnA (read only) 4 01-02-2007 11:57 PM
needed urgently a.p.vinodh Open Source 5 26-01-2006 11:48 AM
New rig help needed urgently kau_therock QnA (read only) 5 22-06-2005 01:10 PM
Cannot shutdown.Help needed urgently!!!! harpoon QnA (read only) 1 25-04-2005 12:02 AM
