Old 12-08-2007, 11:56 AM   #1 (permalink)
hansraj's Avatar
Default can bluetooth be used for pc-pc communication
hi fnds....my lappy is bluetooth enabled and if i put a bluetooth dongle in the desktop then can i access the files of both pcs on each other just as if on lan???
as of now iam using the cable which is a bit messy.
hansraj is offline
Old 12-08-2007, 12:03 PM   #2 (permalink)
The Devil's Advocate
iMav's Avatar
Default Re: can bluetooth be used for pc-pc communication
yes it can be .... for xp it is a little tricky but for vista its very simple ... if both machines have vista then right click on the bluetooth icon next to the time and select 'Join a Personal Area Network' then it will search for the devices if the other machine has vista it will pick it up rather quickly and then u can connect
if u xp then see this link:
http://www.conniq.com/Windows-networ...p-setup_03.htm
http://beingmanan.com
iMav is offline
Old 12-08-2007, 12:52 PM   #3 (permalink)
hansraj's Avatar
thanks iMav.... now can u just tell me what is the data transfer speed ... if u have used or seen someone using it.. i knw that the site says max 3 mbps... but have u used it ?
hansraj is offline
Old 12-08-2007, 01:20 PM   #4 (permalink)
iMav's Avatar
no i havnt used it till maybe this week i will get time to experiment i will post it here wenver i come to know ...
iMav is offline
Mobile communication lab akshar Mobiles and Tablets 1 27-02-2008 11:29 AM
No communication with modem krish Networking 7 01-12-2004 11:57 PM
