Old 11-08-2007, 03:46 PM   #1 (permalink)
Arrow Is battery down..??
While booting PC, it shows following msg..
After pressing F1, OS loads normally.. but I have to configure the date and time..
Now it is very tedious job to do it everytime..
Will I have replace my Motherboard Cell with new one..
please suggest me what to do...
deepakg is offline
Old 11-08-2007, 04:03 PM   #2 (permalink)
Wire muncher!
infra_red_dude's Avatar
Default Re: Is battery down..??
yes, it most likely seems a battery drain unless you've changed the cmos clear jumper on the motherboard.
infra_red_dude is offline
Old 11-08-2007, 04:13 PM   #3 (permalink)
I even not touched the Jumper..
What may be the cause..?
deepakg is offline
Old 12-08-2007, 08:28 AM   #4 (permalink)
Wire muncher!
then its a battery drain for sure. replace it.
Old 12-08-2007, 10:46 AM   #5 (permalink)
Thanks infra_red_dude..
I have changed cell.. and lol it worked...
deepakg is offline
UPS Battery or new UPS ambandla Hardware Q&A 9 18-02-2007 02:34 PM
Digicam using AA Battery thirunavukarasan Cameras and camcorders 8 22-02-2006 09:58 PM
Battery godsownman QnA (read only) 11 27-03-2005 05:06 PM
