Old 06-03-2005, 03:04 PM   #1 (permalink)
Default changing ram values
I heard from someone that windows loads from the 80thposition into the ram is it true.If it is if a program changes the binary value in the 80th position from 1-0 or 0-1,wat will happen
vasanth_12345 is offline
Old 06-03-2005, 03:21 PM   #2 (permalink)
swatkat's Avatar
if the porgram chages the postion of memory then u will get "Page Fault" error!!!!
http://swatrant.blogspot.com/
swatkat is offline
Old 06-03-2005, 03:24 PM   #3 (permalink)
boss ram is volatile
so every time u switch off ur pc theres nuthing in ur ram
certain files do get loaded into the ram while the os boots up .. but these are ( and ofcourser need to be ) refreshed everytime u restart !
hence the point of changing anything in 80th ( or any other mem location ) in the ram just doesnt arise
besides how were u planning to access ur ram to change the "80th position" ?
another quality post by vasanth !
No Mercy, No Limits.
theraven is offline
Old 06-03-2005, 03:37 PM   #4 (permalink)
Default Answer
vo dont teach me about volatile memory and static memory.If u dont know to change the value of ram say dont know.Dont say its impossible
c,mon cant u even figure out that i was talking when the computer was on anyway u can change the value of ram using c (using pointers)if u like try asking any c programmer i was asdking the immediate consequences
Old 06-03-2005, 03:45 PM   #5 (permalink)
swatkat's Avatar
do one thing, u go to DOS prompt, and type debug, and u will get a prompt, here u simply type d and press Enter, u will get a Memory Dump, note the starting address of the dump. u will get something like 1072:0010, this means the programs r loaded from ((1072*10)+0010)th byte in RAM. locations before this one r used by IVTs, some DOS routines etc....so u cannot change it, if u change it, as i said above u will get "Invalid Page Fault" error....
swatkat is offline
Old 06-03-2005, 03:50 PM   #6 (permalink)
listen u prick
i didnt say i dunno how to change the value of ram
i asked IF U KNOW how to do it
with ur utterly noobish questions i dunno what to expect
temme one thing
if after ur windows is loaded u change the contents of the booting mem location somehow (if its still there) then do u think its gonna take effect after u restart ?
moronish questions get such replies
garbage in garbage out !
theraven is offline
Old 06-03-2005, 04:05 PM   #7 (permalink)
swatkat's Avatar
ok...u were talkin of changin the value from 1 to 0 or 0 to 1, i thought u were talking abt chaning the mem. postition of the code....
if u can change the value at 80th position, and if u change it, the code or data at that position gets changed (ofcourse), and the program which occupies that memory location, will crash....
swatkat is offline
