Old 10-08-2007, 12:10 AM   #1 (permalink)
Wandering In Tecno Land
Ecko's Avatar
Arrow PE EXPLORER:--> The Best Resource Hacker
HACKING REVISITED
The Portable Executable Explorer
TYPE
Free To Try (30 Days Trail)
CUSTOMER SUPPORT AVAILABLE
PRICE
$129 ONLY Personal Edition
$199 ONLY Business Edition
DOWNLOAD IT HERE
http://www.heaventools.com/download/pexsetup.exe
http://www.heaventools.com/download/pexsetup.zip
http://www.heaventools.com/download/pexsetup.msi
To BUY
http://www.heaventools.com/order.htm
ABOUT
A PE file ("Portable Executable") is the native format of executable binaries (programs, dll's and drivers) for the Microsoft Windows® 9x/NT/2000/XP/CE 32-bit operating systems. PE Explorer can handle a variety of different PE file types: EXE, DLL, SYS, MSSTYLES, CPL, OCX, BPL, DPL, SCR and more (including executable files that run on MS Windows CE platform).
PE Explorer gives you the power to look inside these PE binary files. PE Explorer contains a whole host of powerful analysis and editing tools for working with PE files. It comes with a PE Header Viewer, Section Editor, Exported/Imported API Function List Viewer, Syntax Lookup, Digital Signature Viewer, Resource Viewer/Editor, Dependency Scanner, and a Disassembler.
In simple words it can be used to modify any windows file and customize it to one's own needs
FEATURES
-> Win32 DISASSEMBLER
-> PE HEADER VIEWER
-> SECION HEADER EDiTOR
-> DATA DIRECTORIES VIEWER
-> FILE REPAIR
-> DLL EXPORT VIEWER
-> EXE IMPORT VIEWER
-> DELAY-LOAD IMPORT VIEWER
-> MANGLED NAME UNMANGLING
-> EXPORTED IMPORTED API FUNCTION LIST VIEWER
-> SYNTAX LOOKUP
-> DIGITAL SIGN VIEWER
-> RESOURCE VIEWER & EDITOR (Resource Types Supported)
-> DPENDENCY SCANNER
-> TIME DATE STAMP ADJUSTER
-> DEBUG INFORMATION REMOVER
-> SUPPORTS PLUGINS
To know completely about those features visit
http://www.heaventools.com/pe-explorer-tour.htm
For Screenshots
http://www.heaventools.com/scrshots.htm
ONLY FOR THOSE WHO KNOW WHAT THIS THING IS
Born in Windows Die In Linux © 2009-10 All Rights Reserved.
Learn Linux : www.linoob.com (Official WebSite)
Ecko is offline
Old 10-08-2007, 04:23 PM   #2 (permalink)
The Frozen Nova
casanova's Avatar
Default Re: PE EXPLORER:--> The Best Resource Hacker
Sounds interesting. Thx for sharing
www.nerdweed.blogspot.com
casanova is offline
Old 13-08-2007, 02:47 PM   #3 (permalink)
Ecko's Avatar
Must Have For C*acke*s and software developers
Ecko is offline
Help, error in using resource hacker Ishani Tutorials 1 22-10-2006 10:00 AM
use of resource hacker prashantban Software Q&A 2 21-10-2006 03:14 PM
Resource Hacker:: qudra Tutorials 1 02-09-2006 09:25 PM
resource hacker vandit QnA (read only) 3 21-08-2005 04:03 PM
Resource Hacker The Incredible QnA (read only) 3 05-06-2005 06:07 PM
