Old 06-03-2005, 11:57 AM   #1 (permalink)
mekalodu
iinfi's Avatar
Default !!! Help !!!
hi
i m new to PHP ....
plz tell more abt it ...
its a server side scripting ... i know that ..
which sever sud i use to deploy PHP .... where can i get the compiler ...
plz help
thanks
mekalodu
iinfi is offline
Old 06-03-2005, 02:26 PM   #2 (permalink)
You can use Apache server the most famous web server especially for PHP...and then you can download the compiler from http://www.php.net/downloads.php. But downloading them seperately and configuring them is a bit difficult for beginners...instead you can try to use PHPdev or PHPTriad or any other complete packages[there are a lot of them], which provide all the essential softwares such as Apache, PHP, MySql together.
Known is a Drop, Unknown is an Ocean...
[lokesh] is offline
Old 06-03-2005, 03:27 PM   #3 (permalink)
mekalodu
iinfi's Avatar
hey cant i use SQL server 2000 or oracle with PHP ??
mekalodu
iinfi is offline
Old 06-03-2005, 03:36 PM   #4 (permalink)
Just Do It
Charley's Avatar
Follow these steps to prepare your PHP installation for connecting to Oracle databases:
* Download PHP from www.php.net, install as per the install.txt file, and test if everything is working.
* Install the Oracle Client (or Server) software on your machine and configure SQL*Net to connect to your database(s). See the SQL*Net FAQ for details.
* Edit your php.ini file and uncomment the following two lines (only if your version shipped with pre-compiled extension modules):
;extension = php_oci8.dll
;extension = php_oracle.dll
... otherwise, compile PHP with the following options:
--with-oracle=/path/to/oracle/home/dir
--with-oci8=/path/to/oracle/home/dir
* Ensure that your "extension_dir" parameter (in php.ini) points to the location where the above extension files reside.
Charley is offline
Old 06-03-2005, 03:37 PM   #5 (permalink)
Just Do It
Charley's Avatar
for SQL use this link
http://www.builderau.com.au/architec...0283164,00.htm
Charley is offline
Old 06-03-2005, 03:43 PM   #6 (permalink)
mekalodu
iinfi's Avatar
thanks both of u!!!
mekalodu
iinfi is offline
