Old 06-03-2005, 11:27 AM   #1 (permalink)
Default HELP!
HElp me guys! I accidentally deleted a folder using"shift"+"del". I don't have any recovery s/w installed. Is it posible to recover it any how?
Hard work never killed anybody..........But why take the RISK
indrajit is offline
Old 06-03-2005, 11:59 AM   #2 (permalink)
mekalodu
iinfi's Avatar
as far as my knowledge takes me .... the answer is NO WAY.....
mekalodu
iinfi is offline
Old 06-03-2005, 12:22 PM   #3 (permalink)
Another Brick in the Wall
drgrudge's Avatar
@indrajit, see the links:
http://www.pcworld.com/downloads/col...id,1295,00.asp
http://aumha.org/a/recover.php
drgrudge is offline
Old 06-03-2005, 01:50 PM   #4 (permalink)
enoonmai's Avatar
First off, whenever something like this happens, immediately shut your computer down to prevent Windows or any other program overwriting the data. Get yourself a copy of one of the best freeware recovery software around, PC Inspector File Recovery
http://www.pcinspector.de/file_recovery/uk/download.htm
If the data is on another drive than Windows, you can safely try installing the software in your computer, then running it to recovery your data on the other drive. However if its on the same drive as Windows, the best thing to do would be to unplug your hard drive and take it to a friend's place, plug it in there, install the software on his computer and then recover the data. PCIFR will tell you if the data integrity is poor, fair or good, and that will translate into whether you will be able to recover your data or not.
Playing FEAR XP/LSW2
enoonmai is offline
Old 06-03-2005, 03:38 PM   #5 (permalink)
Thanx to all you guys! Got my folder BACK!
Special thanx to enoonmai, pcinscector did the job!
Actually it was one of my rare mp3 folders. Would have been quite a tedious task to regain those songs....thanx a million times once again !
indrajit is offline
